Mundorf Supeme vs. Mundorf Supreme silver/oil
Mundorf MCap vs. Mundorf RXF who compared them is sound differences ? t.i.a. Last edited by ermes; 3rd February 2012 at 02:28 PM. |
#2 |
Tell you what, you buy them and do some DBT on them and report back to us your findings.
#3 |
Here's one opinion
Humble Homemade Hifi
Laughing up the wrong tree |
#4 |
"Opinion" is the correct term there. No DBT or SBT at all. He does state from the beginning that the tests are subjective.
#5 |
The equivalent circuit doubtless has some aspect of reality, and microphony can't be discounted, but we would suspect rattling coils as being far worse offenders. It's really not possible to make a 10uF capacitor out of pure gold foil and polyethylene without it being the size of a car battery though...
I'll settle for fat yellow 400V polypropylenes at £5 a throw. No snake oil for me! Perhaps the crossovers should be in the next room though? I used to do that with my turntable.
#6 |
Capacitors do make a difference but at an order of magnitude or two below more typical speaker designing issues.
Now, the standard Mcap is good. If you can't make a very good sounding speaker with them then you have other problems. |
#7 |
There's a very interesting and simple apparatus you could make to test capacitors sound quality, in fact I'm surprised no-one has done it yet!
You use the thermocouple idea to balance a system of two capacitors: ![]() You then apply DC or maybe a 3KHz sine wave to this system. The loudspeaker (which may need a little balancing with potentiometers or varicaps to get exactly balanced) should then produce NO OUTPUT. If the capacitors are microphonic, tapping one should produce an output on the speaker exactly like the distortion a capacitor might make. In fact you could place capacitors of different types (maybe even an electrolytic) in each arm, and the difference will be audible. Oh, I amaze myself sometimes!
#8 |
#9 | ||
It's just the old null-impedance idea familiar to all radio engineers. It assumes you make some effort to balance the bridge, but the surprising thing is it can be done in the resistive arms which is rather straightforward. ![]() AC bridge circuits : AC METERING CIRCUITS What makes it particularly powerful, is you can balance a series and parallel LCR circuit, for instance, which is useful to equalise a loudspeaker impedance or fit a impedance matching LC circuit. FWIW, Troels Gravesen noticed Jantzen Superior Z cap did rather better than standard polyprops in a midrange crossover, "night and day!" he said, so there's something in it. Quote:
#10 |
Haven't compared these but have found the Supreme S/O to be too bright for my taste. In comparison, I found the Multicap RTX to be more listenable. Not that I settled on the RTXs after extensive cap comparisons. I just happened to have them to compare with the S/O, and much preferred them.
| FS: 2 Mundorf SIO caps, 0.68uF, used | madisonears | Swap Meet | 3 | 2nd May 2012 07:46 PM |
| Mundorf Supreme caps for sale | Geardaddy | Swap Meet | 6 | 26th October 2011 01:42 PM |
| FS:Mundorf caps and resistors | fas948 | Swap Meet | 10 | 17th April 2011 06:26 PM |
| Mundorf CAPS | VS | Parts | 0 | 14th June 2009 03:56 PM |
| Seeking a source for Mundorf M-caps. | shif | Tubes / Valves | 2 | 21st March 2005 06:34 AM |
| Page generated in 0.11630 seconds (81.42% PHP - 18.58% MySQL) with 12 queries |
