Is there such a thing as too flat?
I've been playing with Martin King's Mathcad transmission line programs, and I've come up with a box for a certain (rather pricy) 5 1/4 inch mid/bass. The design shows a response curve that's razor flat down to about 40Hz and not off too much at 30Hz. I wonder if it would sound boomy in a typical small to medium size room, due to room gain. But then again, I may be fooling myself. The amount of stuffing material called for is well over 1 lb per cubic foot in the middle part of the line. The worksheet has a comment in it suggesting the density should be in the range 0 to 1. Martin, if you are listening, do the calculations break down at relatively high stuffing densities?
Davy Jones |
#2 | |
#3 |
diyAudio Chief Moderator
You probably listen to room gain. Anechoically flat curves sound boomy inroom.
#4 | |
Brown dashed line = Combined response of room gain and baffle diffraction loss for a baffle between 25 to 30 cm Blue dashed line = Example of an adapted 2 Pi loudspeaker frequency response Red line = Resulting in room sound response While this adjusts the substantial room-gain and baffle diffraction loss, the room modes and resonances have not been eliminated! Nevertheless, you will be surprised to which degree the so-far boomy bass has been eliminated too. The ear seems to be tolerant to room modes as long as the overall balance is guaranted. http://www.arsenal.net/speakers/allison/royart.zip (look out - file size approx. 3meg) advance |
#5 |
i have a jBL 2226 in 33hz 175L heres its response=
it sounds very nice!. in my 2.2mx4m room with low ceiling,the walls vibrate noticably with 20watts. im interested in measuring my SPLs at various positions should i just use sinewaves,note each SPL at measured positions and then compare? the subs in a corner position when i get SPL meter i will do this and post results perhaps. cheers |
#6 | |
So, your proposed measurement setup may be all right as long as it is limited to the bass region (up to approx. 150Hz) and you smooth out room modes manually. advance |
| Coral Flat 5 t/s | ballsingtripp | Full Range | 17 | 15th November 2009 08:46 AM |
| flat sub for flat TV | Artmaster | Subwoofers | 0 | 17th December 2008 11:15 AM |
| How Flat is "Flat"? (XT18WO + 27TBFC-G = MTM) | zenon | Multi-Way | 3 | 21st January 2007 03:15 PM |
| Coral Flat 10 | albertli | Full Range | 16 | 3rd August 2006 03:07 PM |
| How flat is a gainclone | Adam M. | Chip Amps | 3 | 29th May 2004 03:16 PM |
| Page generated in 0.09107 seconds (75.07% PHP - 24.93% MySQL) with 11 queries |
