Hi, I'm just getting started with speaker measurements and I am getting this glitch in impulse measurements that is driving me crazy. If anyone can help me locate the source of the problem, I would really really appreciate it. Here are the details, and an image. I would be more than happy to post images of the results of any suggestions. Thanks.
Basic Setup is:
Problem is this little dip at the start of the impulse: (please ignore the short reflection time - this is just an example of the dip) ![]() Things I have tried with no change to the dip:
Any ideas? |
#2 |
You are talking about the first tiny downward inflection right after the yellow cursor? The droop to -.12 befor the upwards swing?
David S. |
#3 |
Yep, oh and I forgot to mention that it is the same in ARTA and HOLMimpulse.
#4 |
Hard to diagnose exactly but there are a few possibilities:
Might be the actual starting shape of the impulse response of the unit. Might be a little electrical bleed through between measuring system output and input. Most measuring systems have internal filtering (anti-alliasing filtering) and it could be connected to that. Have you tried an output to input loop through or test of a wideband electrical device, to see what its impulse response looks like for the system alone? Its not something I would lose too much sleep over (but I understand it bothering you). David |
#5 | ||
As for the filtering, do you mean in the measurement software, the drivers, or the Lexicon hardware, or any of them? Quote:
edit: Oh hey, I do have this image, though. I had the input and output on the other channel, so what you see here is actually a teeny version of output signal, followed/disrupted by a teeny version of the mic input (both bleeding into the disconnected channel that is shown here). I had another one without the mic input, and that shape the first arrow is pointing to tapers down to nothing in a linear / cone-shaped fashion. Last edited by dumptruck; 26th January 2012 at 08:44 PM. |
#6 |
On further reflection:
Electrical bleedthrough is out because it happens after the air path delay rather than at zero time. Can we see an impulse with no truncation on the front half? By filtering I was thinking primarily the FFT program: Holm. Not sure what the Lexicon is dong but it more likely has an analog low pass. Were you saying that with the woofer connected in either polarity that the waveform starts with the little downward hitch? i.e. whether the primary woofer impulse goes up or down the initial hitch is always downwards? This would be a good clue. Its still possible that the true woofer impulse starts downwards initially and then reverses. A straight through test will show you the measuring system impulse response. Connect output to input and measure. Be careful of levels. The measured impulse should be clean and relatively ring free. (pre-ringing and post ringing are possible) David S. |
#7 |
#8 | |||
Also, here is the impulse with a 2mH series inductor on the woofer (attached). Last edited by dumptruck; 26th January 2012 at 09:08 PM. |
#9 |
Repeat one of your measurements with the woofer polarity flipped (best to do both measurements together: 1 with normal polarity and one with flipped polarity).
I see from your woofer-with-inductor impulse that you have quiet preceeding the start of the impulse. It really does start by going downwards. That still might be normal, although I would think the inductor would have rounded it off. David |
#10 | |
Well, I have quiet if I don't check "center impulse peak" before measuring in ARTA (see first attachment), but if I do check that (see 2nd attachement), there is a thing. If I zoom in, it's the same as the main impulse, dip and all, much lower in magnitude. I figure this must be the bleed through from the direct output of the mic. It's over 60ms back, though. |
| Transformer winding - mysterious! | Overgaard | Tubes / Valves | 35 | 13th January 2011 07:25 PM |
| Speaker Workshop Pulse Response measurement problem | mightydub | Multi-Way | 0 | 10th February 2007 06:53 AM |
| Mysterious Output Transformer.... | zxx123 | Tubes / Valves | 6 | 12th January 2005 09:05 PM |
| mysterious magnet wire | jonathan3233 | Parts | 4 | 11th October 2004 02:39 AM |
| Having a problem with impedance measurement. | prash | Multi-Way | 29 | 17th December 2002 04:24 AM |
| Page generated in 0.12462 seconds (84.28% PHP - 15.72% MySQL) with 11 queries |
