Old 5th December 2011, 04:20 PM   #1
Default B&W P6 Tweeter replacement
I have a pair of B&W P6’s with damaged tweeters. Apparently it’s common for the ferro fluid to thicken up over time to the point where the tweeters no longer work. Never heard of this before but this looks to be the case for my pair.
The speakers are long past warranty but B&W does have replacement parts. However at $135.00 US per single unit, plus shipping and duty I’m looking at $300+ to repair. Given that I only paid $700 for the speakers back in the late 90’s (got them used) that’s a bit of a hard pill to swallow.
So my question is, has anyone successfully replaced the tweeter on a P6 with something other than B&W parts?
Old 5th December 2011, 05:54 PM   #2
I just noticed this is perhaps in the wrong forum.
Can a moderator please move this to the multi-way forum?
Old 5th December 2011, 06:30 PM   #3
lduarte1973's Avatar
see this tread , ask goudey what tweeter he used to replace bw cdm 1 se , it´s the same of your P6
B&W CDM 1 SE - inside cables replacement
Originally Posted by goudey View Post
I also use a pair of B&W CDM 1 SE. For me a great improvement came about from disconnecting the internal tweeter and placing a ribbon tweeter on top, with its own crossover. I don't think replacing wires could make the same degree of improvement that the new tweeter did.
Old 6th December 2011, 06:42 PM   #4
These will get them working, and look the part, but how well who knows ? :
HiVi TN28 Fabric Dome Tweeter 297-409
Zaph didn't like them much, Zaph|Audio
but perhaps that is because of the very wide dispersion lower down dropping
output and increasing distortion, they do need crossing 3KHz or higher,
which should be the case with the B&W's, traditionally c/o high.
Sometimes you have to bite the bullet with the choices available.
The hiccup around 7/8KHz isn't terrible, just shouldn't be there.
rgds, sreten.
Response mounted on top of a cabinet, some internal tweaking around 2KHz.
Solid 90dB+ sensitivity, and flat given the unusual mounting arrangements.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 2nd January 2012, 05:34 PM   #5
I just replaced a (one) tweeter for my B&W cdm-7SE with Vifa OC25SC65-04 its spec very close to original B&W tweeter part# ZZ03123. It s fit nicely with some mod. Sound very similar after a week break in compare to another speaker that still an original tweeter and nicer thing : it cost only $10 each from Part Express
Old 2nd January 2012, 06:11 PM   #6
system7 is offline system7  United Kingdom
system7's Avatar
Dried up ferrofluid in tweeters is very common. It's only oil, iron oxide particles and a binding agent. It evaporates after 10-15 years leaving thick gunge!
I stripped mine out on ancient Monitor Audio R300. I may replace it as an experiment, since it ought to damp the sound a bit. About £10 a bottle. Evidently, you fill 3/4 of the gap, then when you refit the voice-coil, it's about right. Most tweeters disassemble easily enough. Most of them, like Morel, can take a replacement voice-coil anyway.
Troels Gravesen removes it as a matter of course when building speakers in this picture guide:
Vifa C17WH-
In the last resort, replacement tweeters are usually standard sizes. You match impedance like 8 ohm, sensitivity like 90dB or whatever the speaker is and find one the same size face plate and cutout hole. Not hard.
Old 2nd January 2012, 06:48 PM   #7
pinkmouse's Avatar
Yup. If you can strip the tweeter down to get the diaphragm and any plastic parts off, then a soak in petrol or commercial degreasing solvent should clear the gap. Wipe the VC gently with a cotton bud in petrol to clean that up, then reassemble. Ebay should sort you out for some new ferrofluid.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
replacement diaphram & VC for tweeter? mondogenerator Multi-Way 0 12th April 2010 08:28 PM
help with replacement tweeter replacement - KLH twenty three indianajo Multi-Way 2 15th February 2010 12:54 AM
B&W Matrix 804 tweeter replacement.. Richard Moon Multi-Way 7 18th September 2008 07:32 PM
B&W 220i tweeter blown,replacement ?? gazzz Multi-Way 3 9th May 2008 12:54 PM
Tweeter replacement for B&W DM330i Netlist Multi-Way 6 7th October 2004 04:57 PM
Page generated in 0.10148 seconds (85.67% PHP - 14.33% MySQL) with 10 queries
