Old 19th November 2011, 08:28 PM   #1
rvrazvan's Avatar
Default Best high-eff budget tweeter(any type)
i am looking for the best high-eff budget tweeter. I want something that can go low and has a nice overall character(nop nasty breakup). I am considering ring radiators, ribbons, CD, and even cone tweeters.
Old 19th November 2011, 08:46 PM   #2
ScottG is offline ScottG  United States
What's the budget? How low? What type of crossover and at what freq.?
perspective is everything
Old 19th November 2011, 09:08 PM   #3
rob g is offline rob g  United Kingdom
Passive/active crossover?
What specific driver/s are you marrying it to?
Two way? three way design?
low crossover and high efficiency are not easy to find in the same drivers. Large waveguide and compression units probably best bet on a modest budget. I haven't heard Compression units in a Hifi speaker though yet, so I cannot comment from personal experience.
However I can say the Heil AMT's sound excellent. May be worth stretching for, that's if you can find them at a special price.
Old 19th November 2011, 09:10 PM   #4
tinitus is offline tinitus  Europe
and how 'efficient'
I guess no point in denying it, tho not always, high efficiency also often results in being less 'smooth'
so despite having no nasty breakup or peaking, and looking smooth, it could still sound 'nasty', or harsh
best budget tweeter I know of is XT19
I found it very easy to handle
Old 19th November 2011, 09:52 PM   #5
Vifa DQ25SC16-04
94 dB/W @ 1 m, good distortion profile, very low cost
Old 19th November 2011, 10:08 PM   #6
18Hurts is offline 18Hurts  United States
Originally Posted by 454Casull View Post
Vifa DQ25SC16-04
+1
Use a third octave crossover filter at 18dB per octave crossed at 2,500 Hz or more and you should be great shape. I was going to use one for a center channel until I figured out I needed a 30mm tweeter crossed at 1,850Hz.
Zaph Audio loves that tweeter BTW... a best buy with very low distortion.
Old 19th November 2011, 10:20 PM   #7
AllenB is offline AllenB  Australia
What about the Selenium CD that Zilch used iin the Econowave. I haven't used it myself but it seems to be what you're looking for.
Old 19th November 2011, 11:24 PM   #8
Speakerholic
Cal Weldon's Avatar
Check out HiVi. Best bang for the buck I know.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th November 2011, 06:55 PM   #10
MHD-220N/RD that treble driver goes loud!
75W max and 104dB/W @ 1m results in ~ 117dBpk (?114dB SPL) @ 2.5m listening distance for a stereo pair.
Even using the 30W limit results in ~113dB @ 2.5m listening distance.
regards Andrew T.
High Eff. Low Budget Sub - Ideas Wanted AdamThorne Subwoofers 13 16th October 2010 02:47 PM
Best high eff fullrange in the 500$ range...? Defo Full Range 51 25th February 2010 05:46 PM
Tweeter 95dB eff and from 1500Hz x-over anyone? Cordraconis Multi-Way 5 27th June 2008 03:33 PM
High eff.. OB w/ WWMTWW JandG Multi-Way 0 24th December 2007 02:39 PM
2 or 4 ohm High Eff FR Drivers? johninCR Full Range 1 16th November 2004 04:34 PM
Page generated in 0.11174 seconds (80.62% PHP - 19.38% MySQL) with 11 queries
