This deluxe VHF compression driver T-350 was for me one of the best sounded horn tweeter system at those days. Much more better than the T35, although the same voice coil and phenol cone (diaphragm) is in use.
In this case follow questions: 1) What could be therefore the main reason? 2) Which currently available horn tweeter systems (except BMSpro) are presently on the marked (I don't find a successor by Electro Voice itself) ? 3) Are there significant sonic differences between the individual years of production? Here some images and URL's from various time aeras: ?? T350 ELECTRO VOICE ??? ?????? McIntosh/JBL/audio-technica/Jeff Rowland/Accuphase/?/?¾????? ?? T350 Electro-Voice ??? ?????? McIntosh/JBL/audio-technica/Jeff Rowland/Accuphase/?/?¾????? http://community.klipsch.com/forums/...t350two23k.jpg http://community.klipsch.com/forums/...t350two23k.jpg GoodSoundClub - Romy the Cat's Audio Site - Electro-Voice T350, T35, + Fostex tweeters. (delay adjust assembly) One offer I have found about the ebay USA, item No 200636124805 Last edited by tiefbassuebertr; 5th August 2011 at 01:43 PM. |
#2 |
ST350A followed using same diaphragm, different horn and then the ST350B with ferrite magnet... Not currently available there should be plenty of ST350B's lying arround. They were in loads of EV cabinets. I've got quite a few and keep finding more - which is unusual round these parts...
John |
#3 |
Originally Posted by tiefbassuebertr V This deluxe VHF compression driver T-350 was for me one of the best sounded horn tweeter system at those days. Much more better than the T35, although the same voice coil and phenol cone (diaphragm) is in use. In this case follow questions: 1) What could be therefore the main reason? 2) Which currently available horn tweeter systems (except BMSpro) are presently on the marked (I don't find a successor by Electro Voice itself) ? 3) Are there significant sonic differences between the individual years of production? 1) The T-350 has a much better horn design than the T-35, it sounds smoother, plays louder (so requires less power) can go lower and has better dispersion characteristics. 2) The Eminence APT driver is available with several different horns, the APT -200 most similar to the T-350, and has more extended response and far more power handling with similar sensitivity. 3) Different magnet structures were used over the years, ceramic magnets replacing the Alnico. The sonic differences were not much, though the ceramic units were not as pretty, and weighed more. Shimming and alignment of the diaphragms in T-35s and T-350s is critical, depending on the care taken, large deviations in sound are possible. If the diaphragm is not perfectly installed, distortion and ragged frequency response result. The voice coil takes very little power to burn, most T-35s or T-350s used for PA use have been re-diaphragmed, and often proper care was not put into the process. If you are not familiar with diaphragm alignment, I’d suggest steering clear of units that you can’t listen to or measure before purchase. The photo on the left below is the APT-200, right is an EV ST-350. Last edited by weltersys; 5th August 2011 at 06:09 PM. |
#4 |
New Fostex 500MkII probably will sound equally pleasant and is little more detailed . It is expensive though. In my friend's system I preffered it to TAd ET- 703 which in my system I liked more than T-350. Jensen RP-302 is splendid too although as old as T-350. I didn't like T-35 at all.
#5 |
I have a pair T350 for sale.
#6 |
Post it on E-Bay. What did you buy to replace it ?-RAAL ?
#7 |
what means RAAL?
#8 |
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#9 | |
#10 |
It is as much related (actually more) as the fact of you having a pair to sell ;0) just put them on Swap or ebay
| Electro Voice Patrician Speaker | VickiV47 | Swap Meet | 2 | 21st July 2011 08:22 PM |
| Electro Voice E-V1244 | TomWaits | Solid State | 11 | 7th June 2011 02:44 AM |
| electro voice mixer | takefive | Instruments and Amps | 6 | 8th June 2010 02:17 AM |
| Electro Voice | dirtyk777 | Subwoofers | 1 | 29th July 2007 11:02 AM |
| Electro-Voice MC12A's | HTRookie | Multi-Way | 0 | 23rd February 2004 02:17 AM |
| Page generated in 0.10552 seconds (81.07% PHP - 18.93% MySQL) with 11 queries |
