Old 4th June 2011, 02:33 PM   #1
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Default Hi-Vi M6a with Vifa XT25TG30.
Howdy folks!
I've got a pair of little 2 ways that I've made quite some time ago (recently remade the cabinets with leftover wood from a tqwt project), using Vifa XT25TG30-04 tweets and Hi-Vi M6a midbass units. Up until now, I haven't put much effort into the crossover, it's been a simple 6db at around 2500hz. I figured it would do for a little while until I had a chance to fuss with figuring out a better one.
I'd be curious to know what some opinions might be on a good crossover point and type. Any input and suggestions are appreciated!
Old 4th June 2011, 02:49 PM   #2
Einric is offline Einric  United States
You could try this crossover network.
The 2500hz looks ok for that tweeter. A 6" should still be able to produce upper vocals and instruments well.
There is a basic rule of thumb, Fs of Tweeter x3 = lowest recommended crossover point.
That being said I might be interested in trying a 2k or 2.2k X-over.
Old 4th June 2011, 02:59 PM   #3
DrDyna's Avatar
Thanks Einric, that looks a lot like what I was thinking about trying first.
Quick question though, does anyone have FRD or ZMA files for either of these drivers so they can be fussed with in Jeff Bagby's spreadsheet?
Old 4th June 2011, 04:38 PM   #4
jerome69's Avatar
frd/zma
David Ralph's Speaker Pages - Raw Measurements - Tweeters for the XT25.
For the M6A, not found on the internet, see this project : ZX Spectrum - undefinition
I have an idea, not easy to do, hope this could help
Old 4th June 2011, 04:41 PM   #5
DrDyna's Avatar
Originally Posted by jerome69 View Post
frd/zma
Yeah, I couldn't find the M6a either. Perhaps I'll fire off an e-mail to HiVi and see if they've got one.
That looks like a decent crossover too, I might have to order some extra parts to try that one though, but not out of the question.
Old 4th June 2011, 05:04 PM   #6
jerome69's Avatar
I forgot a component to suppress the 9kHz peak, add a 0.15uF capacitor in parallel of L1 (2.2mH)
Just a word about the crossover, it is a LR2 @ 2.2kHz. For the XT25 nothing special. But the M6A have 2 peaks, one near 3kHz and an other at 9kHz.
Let us know, how it works
Old 4th June 2011, 05:50 PM   #7
DrDyna's Avatar
Absolutely, I can hear those peaks too and was planning on asking if anyone had corrected them and what they used. This looks like a solid plan, thank you very much!
I'll see how much of this stuff I have in my parts bin already and what I've gotta grab from madisound. I'll let you know how it works out.
Old 5th June 2011, 04:02 AM   #8
wolf_teeth's Avatar
Default Looks decent...
That 10 ohm resistor across the XT25 is a GOOD thing. You will damp the Fs enough where it will no longer be any issue at all. If the XT still buzzes on James Taylor, you'll know it.
WRT the M6a, I think the LCR may take care of the dual-peaks on its own if you reduce the resistor value, and/or decrease the cap size. You'll effectively notch out most everything above the xover point.
Looks like a decent sim.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 5th June 2011, 06:13 AM   #9
chlorofille's Avatar
DrDyna, I use a similar crossover on my Vifa tweeter as well and found that it is a lot smoother and silkier with a 4.7uF series cap instead of a 10uF.
Sand till the end of time
Old 5th June 2011, 09:21 AM   #10
jerome69's Avatar
Yes the XT25 will have a better sound, the crossover frequency will be 4kHz but the Hivi cannot goes so high
Vifa XT25TG30 pair, $1 reserve on eBay critofur Swap Meet 1 15th August 2010 03:41 AM
FS: new Vifa XT25TG30 Tweeters critofur Swap Meet 6 25th July 2010 03:08 AM
Recession prices on Vifa XT25TG30-04 ? jomatecc Multi-Way 0 31st August 2009 01:46 AM
XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM knightat83 Multi-Way 6 24th January 2009 08:51 AM
Vifa D25AG vs XT25TG30 jomatecc Multi-Way 16 23rd November 2008 08:20 PM
Page generated in 0.11225 seconds (83.62% PHP - 16.38% MySQL) with 11 queries
