Does anyone have any information on these capacitors? The big yellow one in the image?
#2 |
There's an Evans Capacitor company in Providence, RI that has a product called Mega Cap.
#3 | |
Thanks for the info. I went through their site and found nothing similar. Evans Capacitor Company -- High Energy Tantalum Capacitors There is also TDK that makes a Mega Cap. I found nothing similar on their site as well. TDK Corporation - Americas Im going to try sending off an email to both |
#4 | |
I wanna upgrade the caps on my crossover In my Energy speakers.I wanna get a rough idea of the quality of these caps. I was told by a local speaker guy that their probably bulk caps and not worth much. |
#5 |
any film is way better than the electros - polypropylene is one of the better film dielectrics - I would say these are the last caps to replace on that XO board even if you believe "capacitor sound" is in any way significant compared to driver quality and actual XO filter response
#6 | |
you don't have to "squint" to hear the diffs, they are utterly different, I am very excited about it-- they might as well *be* another set of speakers for how fundamentally the sound changed energy veritas 2.2i crossover project in the attached pic, the two 5uF signal caps to the tweeter are replaced, and the single 6uF cap for the midrange, underneath those the resistors are also replaced with mundorf supremes the other pic shows it before the tweeter caps were on, you can see the resistors Last edited by sckramer; 16th March 2011 at 05:43 PM. |
#7 | |
The capacitor sound ended up being *very* significant on these speakers. The difference in sound is hard to describe, it's like the original caps emphasised all the fine details, so they got in their own way-- now that emphasis is gone, and you can hear far *more* detail! -- also the sound is freakishly juicy/fluid, the original caps are hashy/grainy compared to these, and I thought *those* were fluid until I heard these! also, now I know what a 3d sound stage sounds like! before it was layered & with depth, but each layer was 2d! Last edited by sckramer; 16th March 2011 at 06:00 PM. |
#8 |
sorry for all the audiophile cliches's -- just trying to honestly describe the diffs
#9 |
Where are they, then?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 |
in parallel with the speaker driver, and also in this case, in parallel with one of the poly caps... so far less influence on the sound, but yeah there's is maybe a little, you can replace them & listen for diffs
i mis-spoke with "in signal path", meant to say not in series with the speaker driver Last edited by sckramer; 16th March 2011 at 06:48 PM. |
| polypropylene 33uf 500v cap | jim5763 | Swap Meet | 0 | 21st February 2010 01:20 AM |
| Polypropylene versus metallized polypropylene | VS | Parts | 8 | 15th April 2006 05:36 PM |
| Xicon Polypropylene Cap for Valve Amp | PTSOUNDLAB | Tubes / Valves | 0 | 22nd July 2004 07:30 AM |
| dayton polypropylene cap, polarity? | zx3chris | Parts | 5 | 31st March 2003 03:16 AM |
| Page generated in 0.13637 seconds (78.39% PHP - 21.61% MySQL) with 11 queries |
