... and if my memory is correct you need to putt the cabinet at 60/65 cm from the front wall, although I never understand if this distance is from the rear of the cabinet or from the front bafle ! I expect it is the distance from the rear to the wall, as a little air gives always the best bass results ! Band pass bass cabinet are not an exception to this rule !
If there's a problem, I have parametric equalisation at my disposal.... and if my memory is correct you need to putt the cabinet at 60/65 cm from the front wall, although I never understand if this distance is from the rear of the cabinet or from the front bafle ! I expect it is the distance from the rear to the wall, as a little air gives always the best bass results ! Band pass bass cabinet are not an exception to this rule !
Until retirement, I worked as an broadcast engineer for 40 years!
Plough your own furrow!
