#21 |
The OP might want to take a look at woofers by Eighteen Sound, a pro manufacturer from Italy.
Some of their bigger models feature 16 and 8 Ohm versions, neo magnets, double or triple spiders, and goodly efficiency. Some woofers by Precision Devices may also fit the bill, but they are expensive, so they actually might not.
#22 |
selenium high q required for closed box. Selenium has that only watch out for the limited xmax. works fine for hifi medium power.
simulation series resistance 0,4 ohm of filter is calculated. http://www.selenium.com.br/site/asse..._pdfManual.pdf |
#23 | |
#24 | |
Best Kris |
#25 | |
I specifically asked about woofers for closed box. Kris |
#26 |
My best attempt so far is a ported box that 'sounds' like a closed box (basically an overdamped response) with a low port tuning (~32hz). Doing that and using activated charcoal to increase box compliance by an estimated 50% and playing some (passive) xover tricks to fill in the otherwise saddle shaped LF response allows me to get 90db + at 40hz trending to 100db/w/m above 60hz in half space in a 100 liter enclosure using a JBL 2220A. Part of the xover is 600uF of polypropylene input coupling capacitance which limits excursion below the passband and give an extra db or two response in the 30-40hz range. This capacitance value would seem a bit low, but this is actually a true 16 ohm system (that I allow to dip to 12 below 40 hz to scoop up a db or two more sensitivity in that range), even though it uses an '8 ohm' bass driver partly due to a custom wound air core transformer in the xover which almost completely flattens the upper BR impedance peak, turning it into into more sensitivity in the 50-80 hz range. I call it the Iron Lawbreaker.
I have considered making a super low moving mass high efficiency 15" driver that might work in a closed box for good bass extension but have not found the time yet. Last edited by thoriated; 12th October 2010 at 02:35 AM. |
#27 |
It may not be low enough but I am running two Acoustic Elegance TD15S to achieve a good response sealed to ~45Hz. As I say, not sure if this is low enough but you could run them in series for 16 Ohms. It requires a big box!
#28 |
This should be ideal, I should've thought about it earlier:
400 EXC SUPRAVOX High efficiency, low fs, light cone, adjustable motor strength (Q), how adorable!!
#29 |
He needs LARGE drivers do this and still have sensitivity.
TD18H from AEspeakers.com is a SICK woofer. Depending on what he considers efficient, I Would even say the AV15H is another incredible woofer. Its actually a subwoofer but its sensitivity is the highest for that class of designs I have ever seen and it digs deep!! Last edited by doug20; 12th October 2010 at 01:01 PM. |
#30 |
Er.... any limit to the 'box' size? If no, how about this
![]() AE TD15M (what?), used in IB (or you can build a box of 1000 liter), and got this: 90dB/w at 32Hz. BUT, driven by an amp with 10 Ohm output impedance. |
| How are these bass units for a high efficiency system? Eminence EMI-1550/Fostex FW405 | sqlkev | Multi-Way | 10 | 15th January 2008 08:16 AM |
| High Efficiency Drivers for HT | MaximumPuffer | Multi-Way | 2 | 17th May 2007 04:56 AM |
| How much bass from four sealed Shivas? | mazeroth | Subwoofers | 6 | 4th August 2005 01:44 PM |
| Multiple bass drivers in single sealed enclosure... | richardkrol | Multi-Way | 14 | 5th March 2004 02:34 AM |
| Bass(ish) driver for 1.5cf sealed box. | sfdoddsy | Multi-Way | 7 | 8th September 2002 07:32 PM |
