Old 17th August 2010, 08:35 PM   #1
DIFORCE is offline DIFORCE  Australia
Default Bracing overkill yay or nay ?
Hi , I just had a debate with my friend about bracing a speaker box.
He says that the minimum amount of bracing ( like 1 cross brace at the middle ) is enough , and that adding extra bracing would color the sound because the air is moving in many random directions and reflect off the braces .
While I said that the more bracing the better ( like B&W matrix method ... magico mini bracing method ... ) to achive zero panel resonance .
So what do you think ?
How about something like this for bracing overkill :
Old 17th August 2010, 09:23 PM   #2
just another
wintermute's Avatar
My current project has small boxes (only 5.5L per driver) so does not need extensive bracing, however what I did find was when I did put a brace in (in the only practical place which was right smack in the middle), that I did pick up a fairly significant reflection off the brace back through the driver cone.
Note that this brace (a piece of 1" square oak) was right behind and in the middle of the driver (probably only 7cm from the back of the driver.
So yes if you have braces directly behind your drivers they may cause reflections that come back at you through the speaker, though the layout you have shown I don't think this will be much of a problem. Before gluing them in place though (if possible) I'd do some near filed measurements with and without the braces, and moving their position around). I'd suggest rather than using square braces that you instead use some dowel (broom handle would probably be ok). This should still provide the torsional stiffness you require and should minimise the effects of reflections off the braces
Did you explain to your friend that it was box resonation causing colouration that the braces were intended to stop. I suspect that whilst improper bracing could make things worse, doing the job properly whilst it will change the sound, will be removing colouration, not adding it
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 17th August 2010, 09:36 PM   #3
the braces appear square only in the sketch , they won't be.
I'm aware of the fact that bracing behind the woofer might cause reflections , I gave the woofer some breathing space behind . ( but in the magico mini the braces are behind the woofer ... like an inch behind ... )
So instead of the early reflections if the braces are dead behind the woofer , there are no drawbacks right ?
I mean look at the magico mini box ... or the B&W matrix that looks like a bee hive right ?
Old 17th August 2010, 11:07 PM   #4
buggers is offline buggers  United States
No drawbacks, and make the baffle double thick also...
Old 17th August 2010, 11:13 PM   #5
Tony.
Hello
How does this reflection appear?
crazyhub
Old 17th August 2010, 11:43 PM   #6
bwaslo is offline bwaslo  United States
Internal reflections off of braces is unlikely to be an issue, I don't think, at least not compared to vibrating panels.
Also, a little experimenting with braces and an accelerometer (and a meauring system) demonstrates that the cross braces as you show don't actually do nearly as much as would rectangular (yes!) braces attached directly to the walls, to stiffen the wall surfaces as much as possible (not just at a point on the end of the dowels). Try to glue the braces lengthwise to the panels, with ends also attached to walls, so as to leave the smallest expanse of panel unbraced as possible. If the walls were drum heads, you'd want them to be the smallest area drumheads as possible.
Old 17th August 2010, 11:47 PM   #7
doug20 is offline doug20  United States
You should build one with bracing and one without then let your friend listen
Old 17th August 2010, 11:51 PM   #8
David Gatti's Avatar
Vibrating panels is a far more serious issue than some very minor internal reflections.
Generally the more bracing the better. Reflections will be minimal - compare the wavelengths invloved with the size of the braces.
I would round any edges off and make sure there's plenty of air flow. You bracing diagram looks very good.
Old 18th August 2010, 12:04 AM   #9
Isn't making sure the soundwave doesnt bounce back through the woofers more important then over-bracing?
It really does not matter what happens internally because if the sound can not escape it would color anything.
Old 18th August 2010, 02:11 AM   #10
gedlee is offline gedlee  United States
Bill
I'd have to disagree here. A cross brace will be far more efective than a single brace of the same size attached to the wall. "Fixing" a point on a surface is extremely effective at stiffening a panel. A brace "on" the panel does NOT "fix" a point, it simply stiffens it, but not as much as the cross brace will.
Most material are very strong in compression, but weak in bending. Wood is a classic example. So a given piece of bracing will work best in compression (cross bracing), not bending (panel bracing).
If you have experimental data to the contrary I'd love to see it, but any structural engineer will tell you that "cross" bracing is far more effective than panel bracing. Just look at any bridge! The entire thing is cross braced.
Goldstar OS-8100 100Mhz oscilloscope: YAY or NAY? jarthel Parts 0 27th April 2007 07:28 AM
Tweaking: Bypassing spindle motor with caps: Yay or Nay? Scorpio(DDMF)! Digital Source 5 25th March 2007 12:58 PM
Ovation Power Supply WANTED.........NAY NEEDED!!!!!!! Lowjacker Swap Meet 0 15th March 2006 01:39 AM
Copper/Aluminum heatsink - yay or nay? thylantyr Solid State 36 1st July 2004 11:11 PM
Cathode Follower? Yay or nay? SHiFTY Tubes / Valves 25 16th March 2004 06:38 AM
Copyright ©1999-2013 diyAudio
