#81 |
Amplitude difference between reference Bruel&Kjaer 4149 and MBHO MBNM 550EL.
#82 |
OK, great thread!
While I do not understand english not yet very well, I have very trivial question. Just starting to build up my spekaer measurement system: using ARTA software (manual 180 pages HUH |
#83 |
EMU tracker:
- Low channel separation. - Every time you power on - the system has to be set to 48kHz or higher. It has internal preamp. Below ECM8000 calibration made by myself. |
#84 |
There has been some talk about soundcards usefullness or not. I have a MOTU UltraLight Mk. III with no technical data at all about the mic preamps. If I manage to locate some data, what in particular am I looking for, and any mini- or max values to look out for?
I am planning to use the Panasonic WM61 if I can find any, and build myself a calibrated mic (calibration file) and hopefully use it directly with my soundcard. |
#85 |
I'm thinking of giving the DIY Panasonic mic capsule a try. However, I'm wondering about the complexity and difficulty for a complete newbie to take on such a project.
As I understand it, you need an output transformer for the capsule, and then a soundcard with phantom power? If I give it a try, the modification feels like a must. I think I've seen two or three different versions of the mod. |
#86 |
#87 |
For those wishing to use the Panasonic WM-61A, here is a link for a Walin Preamp for it.
http://www.madaboutsound.com/prod_de...2&sa=cf&ctid=4 Plus a calibration file. Mods to the WM-61A itself are at Linkwitz lab site.
#88 | |
#89 |
Rebel Samurai!
I made the simple panasonic wm-61 based amp listed here -
<B>How to Build a Condensor Microphone... a Do it Yourself project.</B> It works with my computers onboard sound without any other hardware. I put an on/off switch in it to take it easy on the battery, as I use it infrequently. Last edited by AdamThorne; 23rd August 2010 at 03:50 PM. |
#90 | |
Eric Wallin's Internet Homepage the PCB is not expensive, have a go !!! |
| PC Dac Measurement | supra | Digital Line Level | 1 | 14th July 2009 12:54 PM |
| non os measurement | Bernhard | Digital Source | 3 | 13th September 2006 09:12 PM |
| how to take db measurement | sonu | Multi-Way | 7 | 9th May 2005 03:03 PM |
| New measurement mic in UK | pinkmouse | Multi-Way | 4 | 10th February 2005 05:46 AM |
| Page generated in 0.12721 seconds (75.05% PHP - 24.95% MySQL) with 11 queries |
