Hi Superlian!
Greets:
Tyimo
How did you solve the AN's SPL rising problem from 3KHz? I know that 3khz - 6khz seems to be troublesome on that driver.One of my recent projects: Audio Nirvana Super 8 Alnico and Acoustic Elegance Dipole 10.
Greets:
Tyimo
Hi Superlian!
Greets:
Tyimo
A simple LR filter (0,39 mH + 10 ohm) or digital EQ
Thank you!
Could you tell me more about your crossover?
Greets:
Tyimo
I am not 100% satisfied, i will probably lowpass the lower bass at ca 70 Hz
It is also maybee neccesary to lowpass the upper bass a little bit lower
LP 2 order: 5,7 mH / 300 uF
HP 1 order: 33 uF
BSC: 0,39 mH + 10 ohm
ANAEOB - Audio Nirvana & Acoustic Elegance i åpen baffel - Side 2
My take on the pureaudioproject style OB.
Eminence 12LTA with super tweeter/phase plug. 2 GRS 15PF woofers. Powered and crossed with 2 Crown XLS1000 amps.
Frame is 80/20 industrial erector stuff. Fun to build and endless possibilities.
Wow that looks great! I hope that it sounds even better that they look.
And "being Dutch" my first thought was also about the erector stuff and its price tag...But it looks great...
Did thought about using Eminence Alpha 15A? Just wondering because I am planning a pretty similar build. And maybe I have to look at the GSR units.
Good stuff.
doesnt look crazy expensive, didn't go into details so could be wrong
80/20 Aluminum Extrusion - The Knotts Company Store
Thanks guys. The 80/20 stuff was around $500 not including shipping. And, I already had some short extrusion pieces from leftover projects. Pure Audio wants about twice that for their frame. Another benefit to mine is its adjustability. I can make it wider or narrower if ever needed.
I had Alpha 15A's in for a while. I think the GRS's are a little bit better in this configuration. At least to my ears. This coming from a 15A fan
Thanks,
KC
Thanks,
KC
Thanks,
KC
Nice project. Would you mind posting a parts list for those that might want to build a pair??
kec, as a long term speaker builder (hobbiest) I believe your project must be one of the best sounding ever I've seen on the forum. I love the Eminence Beta 12lta and think it does things typical home hi-fi drivers can't - like recreate massive dynamics and scale with ease. 15 inch woofers just recreate bass in the home better than smaller powered subwoofers. I use Alpha 15s in my setup but have purchased Parts Express buyout Jamo 15" woofers years ago with similar specs and felt the Jamos sounded better - although they both work well. The Jamos, unfortunately, are no longer for sale and I wish I purchased more than 3 at $25 each! I top things off with a pro Eminence compression tweeter and think it works very well but would not discount other tweeters performing as well or even better. Your concentric build might even offer further imaging improvements. Regardless, I'd imagine your setup sounds wonderful. Enjoy!
Thanks Carl and Godzilla!
When I get a chance I'll put together a list of parts.
It does sound good. Really good if you ask me. I know some will say I need to use miniDSP or this and that to overcome this and that, but I went simple and am really impressed with the results (I do have an Ashly XR1001 on the side that I still need to try). My H frames with 15A's and the 12LTA on top was really a good sounding little system. Then I saw the Pure Audio stuff and loved the appearance of the design - and the versatility. First thing came to mind, 80/20. I love working with this stuff. Love the industrial look. Something that might have come out of Terminator 2
Thanks,
KC
Thanks,
KC
- Ultimate Open Baffle Gallery
