Dahlquist DQ-10 flashback
Old 11th May 2008, 06:39 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by stickinsect
mirror imaged.... and that looks ok,I need to unscrew the brackets and move the driver baffles I assume the midwoofer should be on the inside if the speakers are handed.
I mirror imaged one of the 1st pairs of these we had thru the store (even before the idea was mentioned anywhere). You'll need to flip the midbass baffle to keep the piezo in the right place. The backsides of the array also benefit from liberal use of ductseal.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th May 2008, 07:16 PM   #12
stickinsect is offline stickinsect  United Kingdom
The bass units are offset (both the same way) so major surgery would be required to completely mirror image them or is it completely neccessary.
Old 11th May 2008, 07:33 PM   #13
rdf is offline rdf  Canada
rdf's Avatar
Old timer war stories. My reaction to the DQ10 was the same. The only other speakers which came close were big Maggies, the Acoustat X and the Snell Type A.
Ears aren't microphones.
Old 11th May 2008, 07:55 PM   #14
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Dahlquist DQ-10 loudspeaker
By J. Gordon Holt • January, 1977
The Dalhquist DQ-10 loudspeaker has not as yet been formally submitted for review. (The designer tells us he is still working on the low end.) We auditioned a pair at the one local dealer we could find who had the DQ-10s on demo, and were immensely impressed. Obviously, Jon Dahlquist is on to something that other speaker designers have been overlooking, for, despite the multiplicity of driver speakers in the system, the DQ-10 sounds like one big speaker. There is no awareness of crossovers or separate drivers (except at the low end, about which more subsequently), and the overall sound has a degree of focus and coherence that is surpassed only by the Quad full-range electrostatic, which don't go as low at the bottom or as far out at the top.
Any criticisms? Mainly about the low end which, although well-balanced with the rest of the range, seemed somehow unrelated to it. Bass was a bit loose and flabby—which the upper range was not. The designer is acutely aware of this, and has been working to improve the bottom—here we go again!—which is why, we are told, we have not yet received our own samples for testing. Even as it stands now, though, the Dahlquist DQ-10 is near the very top in its price class, and is stiff competition for the no-holds-barred (and cost-no-object) Class A "Recommended" speaker systems.
In our opinion, the Quad still does a tiny bit better what the Dahlquist does extremely well, but the Quad is a very difficult load for many amplifiers, and won't put out anywhere near the sheer volume of of the Dahiquist. A tough choice.
Me says:
DIPOLE BASS MAN! THAT IS WHAT HE WAS LOOKING FOR. GO CLONE!
Old 11th May 2008, 07:55 PM   #15
frugal-phile(tm)
planet10's Avatar
Bass unit isn't as critical...we just left it as is. A new baffle would allow mirror imaging (or a new bass cabinet)
dave
Old 11th May 2008, 10:59 PM   #16
Salas's Avatar
Watch that DQ-10
video
Old 11th May 2008, 11:49 PM   #17
frugal-phile(tm)
planet10's Avatar
Originally posted by salas
Watch that DQ-10
video
That reminds me that Dalquist was using a Large Advent woofer... useful to know if you need woofers.
dave
Old 12th May 2008, 04:59 AM   #18
Instruction book on video clip showed midwoofer baffle on the outside of the array can that be confirmed?Can somebody post a picture of a later mirror imaged production pair.
Old 12th May 2008, 09:09 AM   #19
Salas's Avatar
Its the same thing. You just flip the mirrored channels. If sidewalls are too near in your room, you position the speakers with the domes to the inside, so to moderate early side reflections.
Old 13th May 2008, 02:21 AM   #20
Diogenes is offline Diogenes  United States
Can somebody post a picture of a later mirror imaged production pair. [/B]
Here's a mirror-imaged pair (improperly refoamed) taken from the Dahlquist Yahoo! Group:
More information can be found there including the original patent, crossover schematics, owner's manuals, pictures, owner's discussions and so on.
- JP
Dahlquist DQ-10 flashbackHide this!Advertise here!
Drivers used in Dahlquist DQ-10? PB2 Multi-Way 2 4th September 2011 02:24 PM
Advice on Dahlquist DQM-7's MikeN Multi-Way 2 8th April 2009 01:49 AM
Dahlquist DQLP1 jlm Solid State 0 24th January 2004 01:45 PM
Dahlquist replacements ihearyou Multi-Way 0 11th December 2003 05:59 PM
