Fast, fun, Inexpensive OB project
Old 15th November 2008, 10:51 PM   #91
Pano is offline Pano  United States
Pano's Avatar
Just to bump this thread.
I built a pair of these for myself yesterday, see pics below.
Not using the same tweeter, I've got the old ScanSpeak 3806 installed. The monster tweeter - alas no longer made.
Sounds great with just a 13.5mH coil on the woofer and 5uF + 5.5R on the tweeter. Crossover point is about 1100Hz, acoustic.
As the cutout for the SS3806 is so large, I plan to try a few small cone drivers in its place. E.G., Fostex, TB, Aurasound, etc. Will probably cross them 2nd order HP at about 1100Hz.
My hope is to find a nice, big, open back "tweeter" to mate with the Peerless woofer. That might encourage a few more people to build this fun speaker.
Stay tuned.
Take the Speaker Voltage Test!
Old 15th November 2008, 10:52 PM   #92
Pano's Avatar
back of the beast
Old 15th November 2008, 11:38 PM   #93
Stuey is offline Stuey  Australia
Hi Pano,
Hmmmmmm....I note your first post mentioning about room size - how do you reckon these'd cope with a room of about 65 square metres?
Cheers
Stuey
Old 16th November 2008, 01:10 AM   #94
Pano's Avatar
Good question.
That's a big room.
For about 4 years I ran these tweeters with a cheap 12" woofers in a big sealed box at work. Huge room, about 45x50x22 feet. Or almost 50000 cubic feet. Maybe 7 times the volume of your room. They did very well indeed at only a few watts.
We are talking 12" woofer in a big sealed box vs open baffle, but I know the tweeters can handle it - I suspect the woofer should be able to as well.
Old 16th November 2008, 02:29 AM   #95
Thanks. I've also been considering a 12" crossed to a CSS FR125 but your thread caught my eye...
Some thinking to do.
Cheers
Stuey
Old 16th November 2008, 03:05 AM   #96
Pano's Avatar
Yeah, there's no reson the CSS shouldn't work, just as some of the other small full range drivers like the TB W4-1320SC 4" bamboo or its 3" brother.
Planet 10 Dave suggests I try the Fostex FF85k. It's actually smaller than the tweeter I'm using now!
Old 17th November 2008, 02:31 AM   #97
AdamThorne is offline AdamThorne  United States
AdamThorne's Avatar
I've often seen the little TB 2-inchers, and thought that about the only thing I could come up with to use one for would be as a tweeter that either played unusually low, or was a dipole. Some of the 3 inch drivers would no doubt be good, but for a xo at 1100 I'd be curious to know how the real little ones stood up. There are even some 1 inch drivers floating around, aren't there?
It seems like if they're good for anything this would have to be it...
Old 17th November 2008, 06:27 AM   #98
I've recently knocked up a pair of Hi-Vi B3S (3" driver) sealed boxes for the bedroom (for FM radio only) based on a Zaph design. While I am quite impressed with their sound, I think they'd not be quite good enough for a high range driver in a 'higher quality' speaker.....although they'd make an OK job of it.
Admittedly mine are run full range which I think would affect the treble clarity a tad. Still, they handle cymbals and suchlike quite well.
Great little driver, though, for the give away price.
Stuey
Old 19th November 2008, 02:31 PM   #99
MisterTwister is offline MisterTwister  Tibet
to save money on huge inductor, small inductor and resistor in parallel with woofer can be used. see attached example simulation (not the sls woofer)
Old 19th November 2008, 02:58 PM   #100
badman is offline badman  United States
badman's Avatar
He's right too, great little driver.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Fast, fun, Inexpensive OB projectHide this!Advertise here!
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 03:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 03:51 AM
