I need some pointers or someone to helpo me build a passive eq for the BMS4540ND compression driver.
thanks
It is not you... you are it. |
#2 |
Perhaps this will help, here's an example of a system using the 4540ND with the DDS ENG-1 waveguide
http://www.htguide.com/forum/showthr...8&page=1&pp=35
#3 |
You need a measurement of the compression driver with the horn you are going to use to do the compensation. It would also my be helpful if you have an impedence and phase plot of the driver with the horn installed as well.
At the very least we would need to know what horn you want to use so if someone has done this before they can help you out. Rob |
#4 |
i have no idea what horn to use. a good one i guess.
yeah i kinda figured that i should buy one and a horn then measure the response and impedance with them together.
| Bms 4540nd | JoshK | Swap Meet | 4 | 7th February 2009 07:23 PM |
| 2 bms 4540nd | holger honda | Swap Meet | 0 | 20th July 2008 05:57 PM |
| bms 4540ND buildup? | holger honda | Multi-Way | 11 | 20th July 2008 05:49 PM |
| Waveguide suggestions for BMS 4540ND? | 300Z | Multi-Way | 4 | 29th August 2007 02:59 AM |
| Page generated in 0.06911 seconds (68.79% PHP - 31.21% MySQL) with 10 queries |
