Geddes on Waveguides - Page 622 - diyAudio
Old 26th October 2013, 09:17 PM   #6211
gedlee is offline gedlee  United States
gedlee's Avatar
I was not too impressed with the Dirac guys.
Optimizing a number of points in space will optimize all points, but one cannot say that there is any solution which will improve all points simultaneously, that's quite a different thing, and it would be impossible.
Are we talking about the steady state field or the direct field here? Completely different situations. I was talking about the polar response and hence the direct field if we are talking about room acoustics. Since this thread is about "waveguides" consideration of a rooms steady state response is not appropriate.
Old 27th October 2013, 02:20 AM   #6212
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I think one could be too focused on the technology of audio and forget about music. The only way you can tell whether they match up is to listen to the resulting system. I think we should really listen to a system based on Dirac technology.
Hear the real thing!
Old 27th October 2013, 02:32 AM   #6213
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by dumptruck View Post
Holm works fine on my Win7 laptop, for whatever that's worth.
Also FWIW, HOLM runs great for me under Windows XP. With 7 it crashes from time to time. Under Win 7, I save frequently.
Old 27th October 2013, 03:31 AM   #6214
Markus,
Earl is right on here. Diffraction and real radiation of driver is not one dimensional. Degree to which it is one dimensional is degree to which EQ may be used to correct overall response.
Old 27th October 2013, 07:41 AM   #6215
Banned
I have no problem being wrong but did anybody actually try an EQ based optimization approach and looked at how good or bad it performed?
Old 27th October 2013, 11:38 AM   #6216
speaker dave's Avatar
Originally Posted by markus76 View Post
We're looking at a multitude of linear systems (each point in space). If they are minimum phase and similar enough, EQ can be used to improve things. Isn't this useful?
I tend to agree with this with "improve" being the operative phrase. As Earl points out diffraction effects vary in the polar sense, so no universal correction is available. Still, improvement from one vantage point is likely to be in the right direction from surrounding vantage points. This is a matter of using good judgment and not over correcting deep flaws.
We do the same for LF room correction: if response is measured over a broader listening area then the best correction becomes milder and less individually perfect, but gives general improvement for most seats.
As to baffle step, I would certainly assume this was minimum phase and can and should be totally corrected.
Its worth noting that nonminimum phase issues might benefit from correction as well as minimum phase issues. In the end you will have an all pass function (residual phase issues) but the system will be flat. That seems smarter than throwing up your hands and leaving response errors because a system is not minimum phase. Shouldn't let "the perfect be the enemy of the good".
David
Old 27th October 2013, 11:43 AM   #6217
soongsc's Avatar
The above measurements are measured about at 1M, one EQed based on the 1M measurement, the other EQed based on near field measurement. So one EQs the diffraction effects, the other does not. I have also tried EQing near field at center of dust cap, at the voice coil, and midway.
While not conclusive, the 1M EQ did sound a bit fuzzier than near field EQ in the transients, overall sound had darker background with 1M EQ. Ultimate Equalizer software EQ was used.
After this test session, the amp was improved to provide best performance without software EQ, and also implemented hardware EQ till most auditors felt it was optimum.
Old 27th October 2013, 04:36 PM   #6218
gedlee's Avatar
David
David
If baffle step is a diffraction issue, as I understand it is, then even if it is Minimum Phase, it cannot be corrected globally.
Old 27th October 2013, 05:12 PM   #6219
Banned
We're talking about an effect that is spread in space so looking at a single point is useless.
Old 27th October 2013, 06:19 PM   #6220
DBMandrake's Avatar
Why would you try EQ'ing the drivers near field response close to the dust cap ?
A near field measurement is not even remotely valid at high frequencies even if the cone were a perfect piston and there were no baffle diffraction effects, let alone when there are cone breakup effects.
You need to be at least 3x the diameter of the cone away before high frequency data starts to become valid just for the driver by itself. To include baffle diffraction you need to be further away again. (In theory 3x the largest baffle dimension)
Automated EQ made at a single point in space is never going to work very well anyway because it can't tell what response aberrations are spatial (diffraction etc) and which are not (cone resonances etc)
- Simon
Copyright 1999-2017 diyAudio
