Old 1st July 2008, 09:42 PM   #4131
Lynn Olson's Avatar
Default Re: Richard C. Morgans - Horn Optimization
Originally posted by gedlee
Lynn - thanks for this, a fascinating study. I will have to get the whole paper. The first person that I have read that understands the problem.
You're welcome - good paper, isn't it? Most of it far above my head, but it's clear the author has done a thorough analysis - a little reminiscent of the original Richard Small doctoral thesis papers. Have to give credit to Australian Universities for supporting audio research.
Dr. Geddes, I was wondering about one of the things you mentioned over in the Waveguide thread. Perhaps I misread it, but it appeared that a major source of HOM's was simply the fact the throat size was nonzero - in other words, the smaller the throat, the less the HOM's. Is this a correct reading?
In traditional horn theory, second-order nonlinear distortion is assumed to primarily originate from the throat geometry, but as described in the 2002 Voishvillo paper, the major source of second-order air nonlinearity is actually between the diaphragm and the rear surface of the phase plug, and other small-dimension parts of the phase plug.
If throat size is an open variable, and you had a free hand designing the phase plug, would smaller throats have better performance in an OS waveguide - say, half or quarter-inch? Or would that be flirting with second-order distortion from air nonlinearities?
John Sheerin and John Janowitz, thanks for the commentary about the distortion curves of the Beyma drivers. 0.1% third-harmonic distortion at 95 dB SPL seemed too good to be true. That puts the BMS 18N850 in a more favorable light, particularly considering the astonishing drive level. You could actually plug the 18N850 into the wall in North America (1800 watts at 60 Hz and 120V RMS) and it would survive for a little while. I wouldn't want to be in the same town, though.
As for a potential TD 18-incher, I'd vote for 40~50 mm Xdamage, as with the Beyma and BMS drivers. It would be nice not to have to babysit the driver against wayward LF content from movies or techno CD's. Performance somewhere in the Beyma and BMS league would be desirable (highish Fs, Qts, and efficiency), and I'd vote for silicone/Aquaplas-damped double spiders to minimize undesirable side-to-side rocking modes. Double spiders also offer the option of push-pull distortion cancellation by reverse-mounting one of them, which seems like a clever and easy-to-do idea.
One of the things I'll be mentioning to Great Plains Audio is applying Aquaplas (now called Antivibe) to the tangential surround of the aluminum compression driver diaphragm. JBL applies Aquaplas/Antivibe to the whole diaphragm when you buy a 435Be, but I feel this is a mistake. The part of the diaphragm with the most chaotic radiation is obviously the surround, and it's an area where mass-damping and outright suppression of radiation is desirable. That is NOT true of the diaphragm dome, where low-as-possible mass and uniform emission into the phase plug assembly are primary goals. Raising the mass of the diaphragm is extremely undesirable, since it depresses efficiency and decreases HF extension.
Since the dome of the diaphragm and its surround operate in completely different ways, and in fact have completely different functions, it only makes sense to treat them differently, rather than applying damping goo to the whole thing. Adding a bit of mass damping to the surround seems like a good idea, and is likely to improve the mechanical termination between the moving diaphragm and stationary mounting ring.
Old 1st July 2008, 10:13 PM   #4132
LineSource's Avatar
The Pyle website does not have T/S parameters for the PDW21250 that Magnetar uses. If anyone gets a manual from Pyle, would you post T/S data...Thanks...
Current limited specs......
Model PDW21250
Brand PylePro
21'' High Power Subwoofer
8 Ohm Impedance
1000W RMS/2000W Peak Power
22 Hz Resonance
Frequency Response: 22 Hz - 4K Hz
Sensitivity: 1W@1M: 107 dB
Magnet Weight: 350 Oz
4'' Aluminum Voice Coil
Diameter: 21.8''
Mounting Depth: 10.2''
Die-Cast Aluminum Frame LJD
Old 1st July 2008, 10:17 PM   #4133
Lynn Olson's Avatar
Umm - 22 Hz Fs and 107 dB efficiency? Is this a car-stereo specification?
Can I buy a Flux Capacitor as an option if I feel in the mood for time travel?
Old 1st July 2008, 10:45 PM   #4134
ScottG is offline ScottG  United States
Originally posted by Lynn Olson
Umm - .. 107 dB efficiency?
Naw.. Thats the nasty peak at 1.7 kHz that you have been trying to avoid.
perspective is everything
Old 1st July 2008, 10:57 PM   #4135
Send a message via AIM to John_E_Janowitz Send a message via MSN to John_E_Janowitz Send a message via Yahoo to John_E_Janowitz
Default Re: Re: Richard C. Morgans - Horn Optimization
[B]
Hi Lynn,
A few things regarding Xdamage. To me, Xdamage is the point at which you can bottom the VC on the back plate actually causing damage to the driver. Xmax is the magnetic limit at which the BL curve drops to 70% of the rest value. Xsus is the useable suspension limit before Kms goes way up. That said, the surround we use is the same as the surround from the EVX180B's. They specify Xlim of 25mm. I'm not sure if that Xlim is their damage point, or the limit of the suspension travel. That surround IMO should but Xsus at 18-20mm, although they claim it can move farther. We have about 42mm physical one way travel before the coil can ever hit the back plate. Quite simply you can never bottom the coil without tearing up the suspension. Also by the time you get to 20mm, the Bl is dropped to only around 30-40% of what it is at the rest value. This means you'd need enormous amounts of power at those excursions to push the driver far enough to damage itself.
So, this leads to a few options. We would do 2.5" VC versions of all the current TD motors, but in the 18" size. A 4 layer flat copper, 4 layer flat alum, and 4 layer round copper will all be options at this point. All in the 14mm Xmax range. Expect these to be in the 96-98dB range. A midrange option with shorter light coil will be just upwards of 100dB. Then the high Xmax version will have 22mm Xmax, 30mm one way suspension travel and 34mm physical clearance inside the motor and around 93-94dB. TC sounds had a progressive roll cloth surround that would do 32mm or so quite well. For most applications though, the 14mm Xmax models will be quite sufficient.
Regarding the spiders, the push pull mounting of 2 spiders does help reduce non-linearity. The problem in most all cases is making it fit in a frame. Standard frames are often a standard depth. For example, EV, Eminence, Beyma, etc cones all drop right into our standard cone and the spiders line up height wise perfectly.Stacking too spiders directly on top of each other will cause all kinds of issues with them rubbing and wearing, so you need space between them. Since the spider can't go down, the cone has to be made more shallow. That now gets into tooling a totally new cone and all the issues involved in that. Also, having space on the VC form between the cone and spider, or between multiple spiders introduces another point of resonance. In an 18" driver it would be much higher in frequency and not be an issue in the useable bandwidth, but in other drivers it can be.
Also of interest is that in a traditional woven material, most non-linearity comes from the weave in the material itself. You can have up to 300% variance in the linearity around the diameter of the spider due to the way the weave goes. Now if you stack too spiders and put the weave at a 45degree angle to the one above/below you help to cancel this out. Aligning the two with the weave in line with the other one multiplies this nonlinearity. A non-woven cloth for a spider is much better, although not readily available yet. We've been waiting on someone to get this closer to production ready for awhile. For damping, we have spent a lot of time working to get rid of any issues with resonances on cones and surrounds. CP Moyen makes many dampers that can be used on cloth surrounds, spiders, etc. Spiders have not proven to be a major issue in most cases. If you can identify bumps in the impedance curve with corresponding bumps in the response curve, you can typically trace them down to cone resonance, surround, spider, etc. However if you don't see these issues, simply coating a spider may do more harm than good. The more porous the spider, the more heat can escape through it.
John
Old 1st July 2008, 11:49 PM   #4136
Banned
Of course it is not true (107 db) but I'm willing to bet you both 100 US Federal Reserve Notes you will not find a better bass driver to be used on an open baffle for under 150 US Federal Reserve Notes. LOL -
Now go back to your 'beyond the oreo' fantasies!
Old 2nd July 2008, 12:01 AM   #4137
Banned
A good 18" driver will have .1 percent distortion above 40 cycles at higher levels then that! Try a JBL 2242 in a horn - LOL "too good to be true" Maybe some time next year we will see your graphs ????
Old 2nd July 2008, 12:05 AM   #4138
gedlee is offline gedlee  United States
I read the whole paper and he didn't quite get the history right. He must have gotten my book about 1/2 way through the thesis because there is no mention of it in chapters 1-3 and in fact much of what he talks about there is described in my book, but he doesn't reference it. Then by the later chapters he is taking things directly from the book. I found this confusing until I realized that the book would have come out right in the middle of his project, so I guess its natural that he picks it up in the middle.
The one thing that he does not point out is that his optimization is for a waveguide in a sphere. He might find different results for different enclosure geometries. This is the problem with his approach - it is very specific for a very specific situation.
The part of his experimental data that got my attention was how often the mouth velocities were non-axi-symmetric. I have wondered about this and expected it would be the case and his data clearly shows that it is - or can be.
Morgan is also the only other person that I have read that recognizes that HOMs can have an evanescent aspect to them. He got a lot of things right, although his major contribution was in technique rather than specific designs. His "best" designs all looked like OS waveguides with some slight modifications at the mouth. This certainly wasn't new to me. He also seemed pretty clear on the goal - constant directivity with frequency. I'm afraid that the horns that you have choosen don't have this feature. Constant directivity does not apear to be a major requirement for all designers.
I'm not sure that one can say that there is a major source of HOMs because there are many sources and the contributions will differ with the specific situation. The smaller the throat the higher the cut-in frequency for the HOMs, so in a sense, yes the smaller the throat the fewer HOMs there will be IN GENERAL, but not necessarily always.
Old 2nd July 2008, 02:39 AM   #4139
Do you have any data to back this up? I remembered a FEA run I did about three years ago on a tangential surround diaphragm assembly. I went back and looked at it again. It was modeled in 3D to get the tangential compliance, so I didn't do an acoustic simulation, but I did look at the mechanical modes. I looked at the first 100 modes and did not find one where the surround was significantly resonating in any way. This covered almost 1 decade of response. Note that this geometry is not the 288 geometry. It also may be that all the modes I looked at do not contribute significantly to the output of the driver - I was looking at shape, not magnitude. It may also be that the surround resonance is the only secondary resonance that really does contribute to the output of the driver, but personally I'm not convinced of this for the tangential surround shape. Now if you have a direct radiator with a surround that's much softer than the diaphragm, sure, the surround will have some issues. Or if you have a compression driver that uses a surround that's made of a softer material than the dome. Anyway, I'd be very interested if you have some information on this.
For example, mode 53 (about 5 times resonance). Color scale is displacement - blue is zero, red is max.
Old 2nd July 2008, 03:57 AM   #4140
Lynn Olson's Avatar
The reference is Murray and Durbin of JBL, published in 1979. Since the results appear to depend on small manufacturing tolerance errors, it's a good question how repeatable they would be. The claim that the JBL diamond suspension is more immune to these variations is not backed up by the data shown in this paper - only one example of the new suspension is shown.
The reasons for JBL to convert over to the diamond suspension (as opposed to tangential) are not very clear. This was the same time that diaphragms were failing in stadium rock applications, and in movie theaters that were using the new Acousta-Voicing equalization system. JBL switched to diamond suspension and titanium, while Altec switched to a different aluminum alloy (Pascalite) and retained the tangential suspension that went back to the WECO days.
Emilar (now Radian) retained the traditional aluminum diaphragm and used a plastic (Mylar) surround. My limited understanding of the situation with soft surrounds is that they can be prone to rocking modes (this is certainly true in direct-radiator midrange domes) and may have unexpected dips and peaks at the bottom of the working range.
Page generated in 0.15787 seconds (59.56% PHP - 40.44% MySQL) with 11 queries
