markaudio 12P in superpensil --advice needed - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 7th November 2013, 01:38 AM   #1
kp93300 is offline kp93300  Malaysia
Default markaudio 12P in superpensil --advice needed
My carbinet is ready and i need some advice :
1) Do i need to line the inside of the carbinet with Insuflex--the aircon duct insulating material ?
2) The carbinet is braced and i intend to place extra bracing to support the polyester fill in the carbinet . Is this necessary ?
3) What internal wiring works best with the Alpair12p? Solid core or 18G multi-core?
thanks
kp93300
PS i have trouble uploading the pictures.
Old 7th November 2013, 02:37 AM   #2
frugal-phile(tm)
planet10's Avatar
1/ optional, but some inner wall damping near the driver to reduce reflections might be helpful
2/ At the densities used, and with the braces you already have, friction will usually hold it in place
3/ we use a pair of 24g solid CAT 5 strands.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th November 2013, 03:13 AM   #3
Hi dave,
thanks for sharing your experience.
What is the sound difference between solid and multistrand?
I notice that many fullrangers use cat 5 cable.
kp93300
Old 7th November 2013, 05:53 PM   #4
Bob Brines's Avatar
"We" use Cat5 because that wire size is sufficient at the power levels most full-range drivers will handle. There is a technical advantage to thin wire, whether it can be heard or not. On the other hand, I am building a pair of speakers with 18ga silver plated copper because the customer thinks he hears the difference.
Bob
Old 8th November 2013, 09:41 PM   #5
What kind of material would you use for this application, dimensions etc?
Thanks a lot
Charles
Old 8th November 2013, 10:23 PM   #6
frugal-phile(tm)
planet10's Avatar
I'd use 12mm Ultratouch cotton felt, but any similar thickmess wool or cottom felt would suit.
dave
Old 9th November 2013, 08:21 AM   #7
chrisb is offline chrisb  Canada
dave
pretty much what Jeff did with his, and they work quite well
now on sabbatical
Old 9th November 2013, 12:12 PM   #8
dave
Thanks a lot!
I can only source either 10mm or 16mm of this...
Will this do?
And if so..which thickness would you rather use?
Charles
Old 9th November 2013, 03:29 PM   #9
larryldspkr's Avatar
Go for the 16mm, should be good!
Larry
Old 9th November 2013, 06:45 PM   #10
frugal-phile(tm)
planet10's Avatar
+1
dave
Pensil and superpensil for A12.2 P kp93300 Markaudio 56 5th October 2013 04:13 PM
Mark Audio A12P SuperPensil Buildlog RonVinyl Full Range 65 19th February 2013 02:37 PM
Advice Needed grungeman91 Tubes / Valves 2 19th March 2011 09:26 PM
Help and advice needed please.... smoothbreed Subwoofers 1 5th February 2007 11:11 AM
Help/advice needed jjs4028 Multi-Way 13 11th October 2006 11:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
