Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th September 2011, 01:23 AM   #41
tinitus is offline tinitus  Europe
ah, ok
my laptop has mic/line input and head phone out
and I can get some kind of EQ software
cost nothing to try it
anyone know if I can convert a stereo headphone out to a balanced mono signal ?
Old 20th September 2011, 10:27 PM   #42
my, this fet amp looks just like tube amp
Old 21st September 2011, 12:40 AM   #43
ChrisA is offline ChrisA  United States
Originally Posted by tinitus View Post
jfets are supposed to be the masters of hi-Z input
how high input impedance can we achieve using tube only ?
The control grid of a triode tube has very high impenence. It's basically an open circuit. But you can't use it that way. You must provide a path from grid to ground and the minimum size grid leak" resister will be found in the tube data sheet. For most preamp tubes I thinkit's about 2M but "everyone uses a 1M grid leak resistor and most of these get soldered to the input jack. The input impedance is the same as this resistor.
But ask yourself, do you really want more than 1M? Why? I think you will get even more noise pickup from the environment
Old 21st September 2011, 05:12 AM   #44
[QUOTE=ChrisA;2718397
But ask yourself, do you really want more than 1M? Why? I think you will get even more noise pickup from the environment[/QUOTE]
yeah
I now also think anything above 100K ought to work
Old 21st September 2011, 06:11 AM   #45
yeah
No, you really don't want to plug your guitar into an amp with 100K input impedance. the pots in the guitar across the cable are 250K They are in effect in parallel with the amp and you know has parallel resistors add. The amp needs to be high relative to the tone pot.
Old 24th September 2011, 12:05 AM   #46
ahh, I often go back and read again, in case I missed something
looking at ecc81
it says 1M limiting value
I suppose this means 1M is max recommended value 'grid leak resistor'
but if thats also the resulting imput impedance, it would be just fine
so far so good
Old 24th September 2011, 10:16 AM   #47
just remembered I have some OPA627, OPA637 and OPA2107
any suggestions ?
btw, my power amp might have convenient additional +/-15 out(200ma)
Old 6th October 2011, 10:24 AM   #48
a few links
Articles and Schematics
Guitar Effects Projects - Richardo's Pages
Francis J. Deck
http://www.national.com/an/AN/AN-32.pdf
Old 21st November 2011, 03:06 PM   #49
this 'thing' has instrument hi-Z input, and connects directly to USB port
even has headphone out
not really cheap, but what else do you need
plug it into your home stereo media streamer
or via PC with all kinds of software
and thats it
very tempting
Old 24th November 2011, 01:44 PM   #50
good stereo amp coming to me, in a few days, I hope
actually I built it, some years ago
might be a bit early days yet, but I will need a preamp
and this is what I have in mind
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2013 diyAudio
