Marsh headphone amp from Linear Audio
Those new boards look real nice....... adding the trim pot is a nice addition....I think I would like to use them for another amp using the higher voltage OP devices and a new PS for 24vdc. For lowest possible distortion with low Z headphones.
BTW - is anyone having a hard time matching the input jfets? I ordered a lot of them at eBay and all the ones I could get seemed to have the Id I speced/test for missing !?
Original ones were new from USA distributor (Fairchild) and I could find plenty in a small batch.
THx-Richard
0dBV into 250 ohms -- using a lab supply (not a super-regulated low noise supply):
Early in this forum... I gave my measured data for low Z but more recently, I have found the distortion is even lower into low Z loads when I use the +/- 24vdc supplies... which need the higher voltage output devices... although I did test it with originals to 24 v and nothing smoked. But wouldnt recommend other try it. I am going to the higher voltage supply and OPS then will give new numbers here.
THx-RNMarsh
using all original p/n and +/- 15vdc power supply -- Here is THD into 50 Ohms:
1v rms and 2v rms - no filters used:
THx-RNMarsh
So Richard, how much more do you want? 🙂 I do enjoy the amp with the dual power supplies. Open, dynamic, fluid in a natural way, transparent and layered. Hey, sounds good to me. I did add some caps right after the PS's, then on to the board. I also used some Black Gate non polar for bypass. Love those BG's.
What PS circuit are you using?
THx- Richard
They are just some simple sealed units from Jameco. I will have to look at their number. Everything fits in one case. Normally I like a PS with umbilical and mess with it until I get what I like but in this case I just wanted to get everything done. With the caps that follow it there is a nice reserve and the DC is clean. I first built it with one PS and because I like either dual or what I call pseudo dual PS, I put in the second and noticed a more open, dynamic and layered presentation.
I wish I had more gain at times.
I am listening with the new HiFiman HE1000. They are compared to some of the finest headphones currently made and in some respects, better than the R10 and more open sounding.
Has anyone done a balanced amp with these boards? 2 boards and 4 power supplies and up the voltage and components to 24 volts. I am glad I put the Goldpoint volume control in. Better made than the DACT, which just copies what Goldpoint does. I also used my high purity dead soft silver for all wiring except some of the power supply connections.
Who will be making the ortho headphones?
-RNM
Hifiman, out of China. They have made orthos for a few years now with the HE-6 considered top headphones but requiring a lot of power. These are much easier to drive and are even better sounding and are being compared to the best in the world and are possibly the best of all current headphones. They will retail for 3,000.00$ They are also much lighter than many ortho phones. The transducer material on these is so light that it almost floats on the air but yet very strong. They have the speed of an electrostatic but with a much deeper and solid and articulated bass foundation.
The DIY amp does great with them and this phone is so transparent that it changes with whatever you are driving it with so what you use, needs to be good.
