Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 26th April 2011, 10:07 PM   #61
AUDIODH is offline AUDIODH  United States
AUDIODH's Avatar
Right on, I so agree with everything you said!
Old 26th April 2011, 10:11 PM   #62
RocketScientist's Avatar
Originally Posted by AUDIODH View Post
Let's remember most electro-mechanical transducers are at or near 1% THD. So if a tube design introduces a little of it's own, doesn't necessarily mean it's bad. Just Sayin'Attachment 220424
That's a common myth, but it's not true. Most headphones someone is likely to use with a headphone amp have THD around 0.1% or even less at typical listening levels. There are plenty of tests that demonstrate that. I've even seen 0.01% midrange distortion on headphones.
There are also plenty of studies that have shown even 0.1% can be audible. It depends on the source, type of distortion, duration of the distortion, listener, volume, etc. But tests have shown the 3rd and higher order harmonics can be heard down to 0.05%.
And, finally, there's the "cocktail party effect" that's also been proven in studies. Much like picking out someone's relatively quieter voice across a crowded room, the ear and brain do the same thing with distortion. The studies have shown we can hear distortion down to about 1/10th the masking distortion. So even if a speaker has 1% THD, if you add another 0.1% THD of a different kind of distortion, it can be audible.
http://nwavguy.com - Personal non-commercial audio blog
Old 26th April 2011, 11:05 PM   #63
AUDIODH's Avatar
Tell where you get a Calibrated microphone that has <~0.1%.
Also, I would like to see the part number and THD vs frequency calibration chart!
Old 26th April 2011, 11:36 PM   #64
jcx is offline jcx  United States
Search is broken in your browser?
basically just back off in SPL and microphone distortion reduces at least proportionately
0.1% @ 120 dB SPL is no probelm for a mic speced at 3% distortion @ 160+ dB
http://www.acopacific.com/chart.html
Old 27th April 2011, 12:03 AM   #65
AUDIODH's Avatar
jcx, No actually, I find no microphone that has that kind of distortion across the audible range.
I can't agree with your statement....distortion isn't linear problem with respect to SPL...it's more about the electro-acoustics and the limitations incurred.
Even LinearX and Earthworks do not specify a distortion in those area's.
One can play games with numbers, but I doubt your Google can find a microphone with less than or equal to 0.01% THD across the audio range. Maybe your browser is more powerful than mine.....
Additionally, those that state very low THD are likely at 1 KHz and not across the audio band. Lastly I'm not sure what the fencing is about with these numbers...what music do you listen too that has distortion that low????
Have you ever mixed in Pro recording studio?? Do you think the very source of the material passed from input to medium with those astronomical numbers? If your lucky a guitar amp is around 10% at the source. Most all studio microphones will not pass the 1% test....again, what are we fencing about here - numbers?
Old 27th April 2011, 12:13 AM   #66
For the HD650 discussed here, the highest peak in the distortion spectrum at HeadRoom is at -93 dB. That's less than 0.003%!
http://graphs.headphone.com/graphCompare.php?graphType=1&graphID[]=853
A tube amp cranking out a typical 1% THD has overall distortion of -40 dB. That's a whopping 50+ dB louder grunge than the Sennheiser's produce by themselves.
And if you think the above graph is somehow wrong, here's another test made on very different equipment that also shows the HD 650's distortion down near zero (2nd graph down):
Sound Quality - Sennheiser HD 650 Headphones Review - Over-Ear
Both of these were made with the microphones you claim cannot have low distortion. Distortion is distortion. If the sine wave is altered by ANYTHING in the signal path it shows up in the spectrum and a THD measurement. In this case both the mic and the headphones are essentially distortion free.
Like I said earlier, it's a common MYTH but that doesn't make it fact. If you have evidence to the contrary, please present it?
Old 27th April 2011, 12:58 AM   #67
AUDIODH's Avatar
Phenomenalism!
I bet if when cryo-cooled the numbers actually go negative. like -0.0001%
Old 6th May 2011, 04:18 AM   #68
Microphones rarely have to capture all of the instruments at once, so intermodulation is largely eliminated.
Maximum output with tda2050 pra3718 Chip Amps 11 10th August 2009 04:42 PM
Driver Choice and Maximum Output pjpoes Multi-Way 7 4th March 2009 02:02 PM
How do I calculate the maximum output of a driver? The Paulinator Subwoofers 2 21st May 2008 01:00 PM
Maximum transformer output RobPhill33 Everything Else 4 17th March 2003 12:50 AM
Allowable impedance of mosfet driver stage Circlotron Solid State 2 30th August 2002 03:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
