Smallest Class A Preamp/Headphone Amp Design?
Yep I already know about that one but I don't think it is Class A and probably not well suited for preamp duty but looks like a cool cheap project.
I was thinking about the Morgan Jones modified HP amp but don't know if they are simple enough for me to make as a beginner. I have no idea what they sound like either. If someone has a BOM and build diary that would be cool.
hey-Hey!!!,
I have built a linestage amp that can serve as a headphone amp. It runs a LTP of 6C45 and a 20k:600/150 output tx. The OPT will deliver a Watt, and the load line shows the tubes capable of roughly 60% more than that. B+ is ~170V. The PS isn't all that small, and neither is its heater supply. Build with a switcher supply and it can be *VERY* small...:)
cheers,
Douglas
Wikkid said:
LOL.. starving student sounds JUST about right!
My interest is in cheapest not smallest..
As I don't listen thru cans very often, but when I do, I'd prefer
good sound...
Lots of cost savings can be had with careful/skilled shopping.
Also, the 'Class A' category is a bit of a red-herring. All SE has to be Class A, and it is trivially simple to do PP in Class A too.
cheers,
Douglas
Bandersnatch said:
hey-Hey!!!,
cheers,
Douglas
Sounds good, can it be built be a complete moron? lol I like the sounds of that one so far. At 1Watt it could be used for biamping tweeters later on right? Ultimately I think that will be how I will want my set up since I enjoy speakers more than headphones but have to do the headphone thing alot in my current situation.
I don't know about 'complete moron'...I suspect that one of those folks would just buy one off the rack...:)
It is fairly simple; single stage LC filter for B+, LC stage for DC heaters. The LTP has a CCS in the cathodes. The negative rail is done with a 25V/450 mA/$6 Radio Shack power TX and some 50V 'lytics. The CCS is depletion-mode Supertex MOSFET based.
The design does need a good OPT. I chose old Chicago BO-2's. They are usually quite inexpensive at auction. Fortunately I now have three; two in service and one ready to be unwound and documented for making more. Go right ahead an' bid them up now...:)
cheers,
Douglas
This headphone circuit (6N1p) - small footprint there
http://headwize.com/projects/showfile.php?file=bender_prj.htm
or (6922)
http://headwize.com/projects/showfile.php?file=cmoy5_prj.htm
will work. Both use a White Cathode Follower and will work with ~300 ohm headphones. 6922 version also has the option of loop feedback to drop down the output impedance even more. I've built a similar circuit (using an EF86 triode connected as the gain section) and found it to be a good performer. The headphone section was admittedly an afterthought, but one of my condo living friends uses it exclusively for his daily listening.
Actually, GlidingDutchman, I take back what I said about it needing to be tube. That project looks simple enough that I might even tackle it! I need to work my way up in complexity of projects first and if it sounds as good as you say then it may be a good one to do. Do you have a parts list? Can that HP amp double as a preamp easily?
