Banned
Joined 2002
Ok i got the boards arrived from briangt. Id have to say that these little parts are a time consumer .. Ill post pics in a day or so guys. I'm not rushing this at all. They do look really nice. the best part about these is that they are gold plated. The solder sticks really fast and easy when soldering smd parts. Well done brian.
sounds fine I´m in no hurry,take it easy.I'm not rushing this at all.
Kram said:I am after a set of boards as well. I emailed BrianGT about getting some of a small run he mentioned in the other mini a thread. Just wondering if these are the same ones.
Either way I would like a set and a group buy as well if there is one.
Mark.
These are the same boards. I haven't actively sold these yet, as I did a small run, and will order more after the first batch of amps has been built.
Brian
Banned
Joined 2002
Banned
Joined 2002
Banned
Joined 2002
kozak said:Could we have an idea of the cost of these kits?
At this point i Dont really know BUT i can say this. It is not going to be expencive..
I have to talk to brian still. And see
Banned
Joined 2002
Banned
Joined 2002
Banned
Joined 2002
Here we go Just taken
Banned
Joined 2002
kozak said:very nice pics. Why didn't you fixed the heatsinks on the bridge diodes?
They wont need it. If they do ll create some small ones..
Banned
Joined 2002
So i just did a test how to clean boards. THIS IS easy.. So the first step is to buy some Flux remover created buy MG chemicals. So the fist thing you do is spray the board with this stuff then scrub it clean with the tooth brush. After that rinse clean with hot-water then spray with cold can of air. to move all the water off fast.. i just did a board and they look really really clean.. I have yet to find any thing else that works well. I was told i could rubbing alcohol instead of water..
Pictures to come if any one interested.
A update of this soon will be mounting these to a heat sink and getting them fired up and running. I am hoping no problems. I cant see any problems arising from these but..
The configuration will be..
4 channels 2 x 2 stereo blocks. each channel will have it's own separate PSU board and transformer.
I have used alcohol,on the boards that is and after flush with water.I was told i could rubbing alcohol instead of water..
Please..Pictures to come if any one interested.
Banned
Joined 2002
Here we go
- Group Buys
- SMD Aleph Mini's
