CRC Power Supply (Class A amplifier)
GB-3 UPDATE
analogdiy 4 boards (confirmed), paid, shipped, delivered
PauloPT 2 boards (confirmed), paid, shipped, delivered
Voysto 4 boards (confirmed), paid, shipped
ravid 4 boards (confirmed)+2, paid, shipped, delivered
touchdown 4 boards (confirmed), paid, shipped, delivered
xrk971 (ver1 or ver 2) 8 boards (confirmed), paid, shipped, delivered
avinunca 2 boards (confirmed), paid, shipped, delivered
AdeS 2 boards (confirmed), paid, shipped
bk856er 4 boards (confirmed), paid, shipped, delivered
Lutto 4 boards (confirmed), paid, shipped, delivered
redarc12 4 boards (confirmed), paid, shipped, delivered
bambadoo 4 boards (confirmed), paid, shipped, delivered
Philipp23 8 boards (confirmed)+2, paid, shipped, delivered
hui13 4 boards (confirmed), paid, shipped, delivered
patriz 4 boards (confirmed), paid, shipped, delivered
Project16 2 boards, paid, shipped, delivered
Prasi+friends 6 boards
asanden 4 boards, paid, shipped, delivered
jpr_pt 4 boards, paid, shipped, delivered
spind 4 boards, paid, shipped, delivered
potepuh 4 boards, paid, shipped, delivered
Dennis Hui 6 +2boards, paid, shipped, delivered
Carmaux 4 boards, paid, shipped
bandol83 4 boards , paid, shipped, delivered
marcus1 4 boards, paid, shipped, delivered
themystical 4 boards, paid, shipped, delivered
aubmar 2 boards, paid, shipped, delivered
ZRXSHACK (6 boards), paid, shipped, delivered
rephil 10 boards, paid, shipped, delivered
ermine22 6 boards, paid, shipped, delivered
ppap64 4 boards, paid, shipped, delivered
JLOP 4 boards, paid, shipped, delivered
ovidiu1, paid, shipped, delivered
slartibartfasst, paid, shipped
pl confirm delivery of packet for bold letter shipments.
I Will be using 2 of this boards for a DIY sony Vfet in monoblocks.
I think 33kuf is enough for the capacitance but don't know what kind of rectifiers are the best for this aplication. The universal psu uses dual rectifier diodes , 3 legged ones. Need advice here.
The other parts used in the universal psu are resistors and the bleeder ones. Can I repeat the values here? Or is there a way to find the right values? I am building the vfet amp the best way with the minimum compromises. Thank you
Hello!
Is there any board remaining? (I need 4)
Thanks,
Pierre
Hi Pierre,
There are no boards left. However I have ordered 50 more as I have been getting some requirements through PM and for local sale. Price will be 5.3 USD per PCB. PCB will be available with me in another 18 days approx.
regards
Prasi
Here is the list
bigaudioscotto 2 nos
vj_audio 2 nos?
ajit 2 nos
Pierre 4 nos.
Hi Joca,
Could you let us know the current demand from amp? and supply voltages?
Once you know the current you could calculate the voltage drop across CRC resistor (ohm's law) and its power rating.
Also with 33kuF, a soft start would be necessary.
You could use ohm's law to calculate power rating of led and bleeder resistors.
e.g. for bleeder, I= V(supply)/R(bleed), Power= I*I*R. Similarly for led as given on the schematic on page 1.
Well, I'm in the vfet forum to understand what are the needs, but meanwhile,
Current demanding is 0,5 amp, I think. The power of the amp is 15W 8ohm, with 22vac supply voltages, 28vdc after rectification. Maybe the 33kuf capacitance is on the high side.
Considering these specs a 0.22 0hm 5w crc resistor would be sufficient. 2 amps current across 0.22 ohm. Bleeder could be 1k5 to 2k2 , 1 to 2w rating be sufficient.
PCB delivered for GB-4 , 50 nos.
h-wan 6 boards
av-trouvaille 6 boards
diya member thro PM 24 boards
diya member thro PM 2 boards
local sale 12
request h-wan and av-trouvaille to share name, address, postal code and paypal via PM.
Hi Prasi
Got little confused with the caps orientation for the new blue mask pcbs? Also the same with the case of the LED orientation and not sure which side has a slight notch or cut for the anode/cathode direction. Can you please help, thanks
