Hi Algar,Hi. Since this new version of the AYA-II will support I2S interface with U.FL miniature coaxial connector, I'm planning in using an external Asynchronous USB interface, much better than the one built-in on the AYA PCB.
I'm already using the very good Amanero in my HQ-9018 ESS Dac.
I designed a little carrier board with local LDO low noise regulators, I2S isolator (ISO7640FM chip) and U.FL output connectors. See included first version of this PCB. I'm planning in using the AYA-II Raw V+PCM supply and I won't install the AYA USB interface parts.
See the included schematic. I won't debate at large my parts choice that was partially done using parts I had in stock. The circuit architecture is inspired from the HQ-9018 PCB, that I know is working perfectly.
Since the TDA1541 is working on +5V and not +3.3V, I added a small jumper on the PCB to select the Isolator chip voltage 3.3 or 5V. There is separated GND, local decoupling, ferrite LC filters, etc...
Is there any way how I can obtain AYA-II Amanero board.
thanks in advance.
- Group Buys
- GB: AYA II TDA1541A DAC (2014 Edition) PCB or Kit
