Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 7th November 2012, 11:47 PM   #691
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 2*I2S FIFO KIT, 2*Dual XO Clock board , 2*S/PDIF Interface, 4 x BIII adapter, 2x I2S backdoor KIT for S/PDIF board, 4x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x
Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 8 x 4" coax cables
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
www.burningamp.com
Old 8th November 2012, 12:15 AM   #692
iancanada's Avatar
This time, for orders less than 100g, I'll get them shipped as letters. For orders less than 500g, I will try to ship them in envelopes. That will make a big saving on shipping for your GBIII. .
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 8th November 2012, 07:32 AM   #693
koldby is offline koldby  Denmark
Added to my order.
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
koldby
What is Home Theatre without good sound?
Old 8th November 2012, 09:49 AM   #694
Universal SMT XO Adapters KIT, 8 x 4" coax cables
I have removed the S/PDIF interface board from my order.
Roumen
Old 8th November 2012, 06:06 PM   #695
andrea_mori's Avatar
Default just for clock
just got from Laptech... HC 49 cold welded polished AT crystal
Frequency: 11.2896 MHz
Mode: fundamental
FL: 2.7 ppm
RR: 10 ohm
C0: 2.6 pF
C1: 12 fF
Q: 160 k
not very bad, now it need the right circuit to keep an high loaded Q
The ideal circuit is the two transistor Butler oscillator, with crystal between two emitters, so it see the lower impedance and its high Q is not affected by the load.
It promises a good phase noise performance, now it's the time for experimenting with it.
Old 8th November 2012, 08:51 PM   #696
BDL is offline BDL  Romania
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
Old 8th November 2012, 11:53 PM   #697
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 1x isolator board kit , 1 x battery management board
Update for Fridrik added 1x isolator board kit and 1 x battery management board
Old 9th November 2012, 12:25 AM   #698
iancanada's Avatar
Mode: fundamental
FL: 2.7 ppm
RR: 10 ohm
C0: 2.6 pF
C1: 12 fF
Q: 160 k
Please let me know your testing result. Good luck.
Ian
Old 9th November 2012, 09:56 AM   #699
palmito is offline palmito  United States
palmito's Avatar
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
Update for palmito added 1x isolator board kit and 1 x battery management board
Old 9th November 2012, 09:49 PM   #700
NicMac is offline NicMac  Italy
NicMac's Avatar
N39 20 x battery management boards
Do I like the battery management board?
2SK1530/2SJ201 sales thread and FET list
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 2789 22nd May 2013 04:29 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2013 diyAudio
