Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 27th February 2012, 07:05 AM   #121
amc184 is offline amc184  New Zealand
amc184's Avatar
No, you can't skip the comparator if you want a clock output that is suitable as a master clock for a CD player (the purpose of the project). You could replace its functionality with discrete components, but it's not something I'd recommend.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 27th February 2012, 07:14 AM   #122
any more pcb's available?
Old 27th February 2012, 07:17 AM   #123
amc184's Avatar
Yes, I've still got a couple of PCBs spare, PM me your details.
Old 17th April 2012, 04:00 PM   #124
andrea_mori's Avatar
Any pcb's available?
Old 17th April 2012, 04:07 PM   #125
Hi Anton
I've finished one LJC module today.
Measuring 4.93V on pin1 of AD8561 vs 5V.
Is it Ok ?
What kind of wire do you use ?
Old 18th April 2012, 10:25 AM   #126
roender is offline roender  Romania
roender's Avatar
Did someone measured the phase noise in frequency domain for this clock?
Old 19th May 2012, 09:16 AM   #127
Can you please elaborate?
What's the function of the comparator? Purely buffering?
thanks
Old 19th May 2012, 09:55 AM   #128
amc184's Avatar
@korben69: That's fine, well within margin. The output connector pattern suits SMA / SMB / SMC connectors, so usually you'd use something like RG316. The cabling isn't critical over very short distances, and the clock should be positioned very close to the point where it is to be used so that the transmission distance is kept very short. The clock isn't designed to drive a transmission line. Sorry about the late reply, I hope the answer is still useful.
@roender: No, I've already answered this question.
@studiostevus: The comparator is absolutely essential, it can't be omitted. Its function is to transform the two out of phase sinusoidal signals from the oscillator into a single squarewave. It's not merely a buffer.
Old 19th May 2012, 10:46 AM   #129
Thanks for explaining.
Any idea about the effect of the comparator on jitter/phase noise...? The data sheet mentions a 7ns propagation delay, no mention of jitter (15ps typical i read somewhere). In any case, i believe that any psu noise to the comparator will result in phase noise...
Worth mentioning is also that not all devices require a square waveform to trigger. Have you tried to use it without?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 19th May 2012, 02:28 PM   #130
amc184's Avatar
The comparator will add some phase noise, but it's not separable from the rest of the design. However, what it adds is by far outweighed by what it does by providing a squared output and the cancellation of common mode noise from the oscillator.
Did you note that the comparator runs off a separate regulated supply to the oscillator?
As long as the waveform is of adequate voltage, almost any wave shape (triangle, sine etc) will work with almost any device. However, one of the significant causes of jitter is noise in the transition voltage of the receiving device. The jitter caused by this is proportional to the slope of the waveform about the transition, the steeper the slope the less jitter. Why would you want to use anything but a square wave?
opamp / low jitter clock for maranatz sweepy DIY HiFi Supply 1 5th April 2011 01:48 AM
FS: Low Jitter Clock PCBs amc184 Swap Meet 6 20th June 2010 07:00 AM
Is this cristal clock schematic would have a low jitter ? gaetan8888 Digital Line Level 8 20th May 2010 03:13 PM
low jitter clock help needed atcgreg Digital Line Level 10 9th June 2009 07:58 AM
Another clock idea for low jitter Bernhard Digital Source 7 29th October 2004 05:05 PM
Copyright ©1999-2013 diyAudio
