Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Surface Finish for future PCB´s
ENIG - Electroless Nickle/Immersion Gold 41 43.62%
Immersion Silver 30 31.91%
Immersion Tin 15 15.96%
OSP - Organic Solderability Preservatives 8 8.51%
Voters: 94. You may not vote on this poll
Old 30th September 2010, 10:03 AM   #121
By the way, Oliver,
How is that EC-Designs output stage coming along? Have you built it already?
Old 30th September 2010, 10:31 AM   #122
dvb-projekt's Avatar
Send a message via Skype™ to dvb-projekt
Yes. I will post a few pictures of it. It sound´s real good, but i am glad to change back to my Tube-I-zator.
It is the difference between good sounding and a live feeling and the latter is what i want
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog
Old 30th September 2010, 05:08 PM   #123
Default 3.3V regulator
I finish testing my 3.3V regulator yesterday. Thanks to Oliver I manage to complete all this without any fuss. I get sharp 3.3V constant after the mod but there's some kinda a heat...luke warm heat after initial start (few minutes) at the heat sink and the current adj. resistor. Is this normal Oliver???? Heat sink size is around 600mmX400mmX150mm.
Old 30th September 2010, 05:26 PM   #124
Hi gabanyayaya,
perfect to hear that every works fine.
Just to verify, here again the recommended mod´s:
Please tell me the voltage over the 5W resistor and it´s value.
Old 30th September 2010, 05:31 PM   #125
LucasAdamson's Avatar
Hi Oliver,
I am looking to buy a transformer or two for my DAC, and a Hong Kong R-core supplier says he can make one with all of my requirements. He wants confirmation of the voltages and ampages I asked for. I thought I'd better check before confirming:
Hello,I can customize this kind transformer for you, according to your requirements,I think the parameters as following is ok:
Input voltage:AC 240V
Output voltage:
0-24V (2 lines 400ma) for -15v DAC
0-12V 0-12V 0-12V 0-12V (8 lines 400ma) for +5v -5v DAC, +5v Analogue, +5v Teralink X2
0-12V (2 lines 2A) for Tube-I-Zator heater
0-120V (2 lines 200ma) for Tube-I-Zator cathode
Output power:9.6W+4.8*4+24+24=76.8W
Does it ok?
regards
Lucas
Old 30th September 2010, 05:46 PM   #126
Originally Posted by studiostevus View Post
By the way, Oliver,
The promised photos:
Here the layout overview with the quick made pcb
I had used some small smd resistors
Old 30th September 2010, 06:18 PM   #127
Originally Posted by LucasAdamson View Post
Hi Oliver,
Hi Lucas,
i would recommend the following values:
1x 0-20V 1A for -15v DAC (20VA)
4x 0-12V 1A for +5v -5v DAC, +5v Analogue, +5v Teralink X2 (48VA)
1x 0-9V 2A for Tube-I-Zator heater (18VA)
1x 0-120V-150V 0,1A for Tube-I-Zator B+ (15VA)
Total: 101VA (W)
With this configuration you have reserves for the transformer.
Also the multiple voltages for the B+ are good, because i have an upgrade cooking, witch needs the 150V tap.
Don´t forget the values are AC and must multiplied with 1.4 to get the DC voltages minus the voltage drop from the rectifier diodes.
Old 30th September 2010, 06:34 PM   #128
Originally Posted by dvb-projekt View Post
Hi Lucas,
Thanks Oliver, yes I certainly did forget the rectifiers. Doh!
Regarding the Tube-I-Zator B+, how can there be multiple voltages on a single pair of AC lines? Surely I must choose 120 or 150 vac, no? Also, does 100mA really leave enough surplus for the transformer AND your upgrade?
Lucas
Old 30th September 2010, 06:43 PM   #129
For the B+ you select only one tap, yes. The 100mA are absolute enough.
The 6N2P-EV has an anode current from 2.3mA±0.9mA for each triode, so we have four triodes with an absolute maximum of 12,8mA.
Old 30th September 2010, 07:44 PM   #130
OK, so the 0-120-150 thing, to be clear:
Is that 4 lines like this: 0-120, 0-150 each at 100mA? This will allow 120v for the B+ and 150v free for whatever you have so intriguingly "cooking."
Sorry if I am being stupid. I just want to be clear before I order the thing.
Lucas
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb-projekt Digital Line Level 130 30th January 2011 01:54 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 25.00%)
Copyright ©1999-2013 diyAudio
