Group Buys Members group buys
Waveguides and horns
Old 11th May 2010, 04:09 PM   #41
doug20 is offline doug20  United States
No problem, I consider this just agressive lobbying (Its the salesman in me! )
I have 3 or 4 individual instersted along with myself for something that is 15" or less in width.
I know all about all horns available these days and there are zero ellipitcal OS choice available and if we just want a 15" OS waveguide we have to go to Geddes. Nothing else is available any more.
18sound has some really nice looking waveguides but the designs jzagaja is offering is unmatched out there in terms of style!!!
I agree with your point that we have zero options for large size horns too! I see no reason that we can not have BOTH orders filled
Old 11th May 2010, 04:23 PM   #42
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
I'm interested. One thing I'm not sure about: is this group buy designated for the Iwata only? Or are you collecting interest in the other horns listed to also add them?
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 11th May 2010, 06:42 PM   #43
jzagaja is offline jzagaja  Poland
Any horn up to 2 meters diameter, min. order 6 pairs or from a list (any quantity).
Old 11th May 2010, 11:14 PM   #44
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
For those that aren't in the know, meaning me... Are these various horns designed to accept the bolt on style drivers? What I'm getting at is, if I was to get in on this group buy it would only be of interest to me for trying out the GPA 902 or 909 drivers, so I'd want whatever would work best with them, which I have no clue lol ??? I guess they would be crossed over at 1200HZ or thereabouts ???? Thinking on eventually making a diy Altec M19 type cab using the GPA drivers...
Old 11th May 2010, 11:22 PM   #45
agent.5 is offline agent.5  United States
I think 6 pairs of 150hz is doable. In your prior post, you mentioned that big horns need to be made in 2 pieces. I imagine that you will need to glue the two pieces together. Is it possible to design the horn, so the enduser can easily glue them together. Doing it this way allow us to cut the shipping volume in half, as shipping a pair of horns require just stacking up 4 pieces on top of each other with some fillings in between.
Old 12th May 2010, 02:08 AM   #46
WithTarragon is offline WithTarragon  United States
Although it is not a "true" Geddes Oblate Spheroid expansion, the "Quadratic Throat" horn by Charles Hughes is quite close. The "white paper" is easy to find on the Web, but it is not very useful. There is a Patent and also a copy of a conference presentation by Hughes and these are posted on the Web.
These (horns / Wavegudes) can be asymmetric (rectangular) and are fairly easy to build yourself (no casting, lathe, or fiberglass invloved). They are fairly close to the the Geddes design, because Dr Geddes goes into a fit whenever someone mentions them.
Old 12th May 2010, 10:55 AM   #47
sendler is offline sendler  United States
Default 1.6" entry
Too bad they manufacture it with a 1.6 inch entry.
Peavey.com :: High Frequency Horns
Scott
Old 12th May 2010, 11:00 AM   #48
Yes, with OSWG you can only fine tune a given throat. Theoretically you can make 1.6" throat and use 1.4 and 1" drivers. Conical duct from waveguide and driver will be slightly longer and quarter wave resonance closer to 1kHz (or Fs). This resonance require additional trap in the crossover.
Old 12th May 2010, 11:52 AM   #49
I have the QSC HPR-152i waveguides already, they measure very, very well and are $14 so we can not go wrong on that front.
What I want is a specific look that follows a specific science. A Small Iwata (no more then 15" wide) is what I really, really want. Im not sure what frequency that is but I LOVE the look.
Also I have a question on the OS12WG, what is the size of the throat on that, I would assume 1"?
Old 12th May 2010, 01:38 PM   #50
Yes OSWG has 1" with fine tune possibility. Larger than 1.4" does not make much sense. It can be sold with a matched driver too (+$50), replacement diaphragm is then $10.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
