Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Which soldermask colour do you prefer for future PCB´s?
red 54 12.13%
green 112 25.17%
yellow 24 5.39%
black 90 20.22%
white 46 10.34%
blue 119 26.74%
Voters: 445. You may not vote on this poll
Old 23rd April 2010, 04:26 PM   #281
dvb-projekt's Avatar
Send a message via Skype™ to dvb-projekt
Originally Posted by Ted205 View Post
* Optical Volume Control
Hi Ted,
send me your order to: diyaudiopcb (at) gmx.com
as written in the fist post. Please let me know if you want also have the parts kit (exclusive the LDR´s).
Best regards,
Oliver
Reference TDA1541A DAC project PCB´s / Tube-I-zator V2.0 PCB / SSHV-Shunt PCB /
Pedja Rogic´s Discrete Diamond Non-Feedback I/V Stage
- Stock status in my Blog
Old 23rd April 2010, 05:24 PM   #282
Originally Posted by parb View Post
george doesnt sell a kit, he sells a finished product.
i kind of wish he sold a kit, it would have made this so much easier, or at least if he would 'license' his kit to one of the guys on the forum to make it easier for diy'ers to build something on their own even if it is a kit.
That is the Optical Volume Control PCB.
Name changing was only on request of the forum admins!
Best regards,
Oliver
Old 23rd April 2010, 10:47 PM   #283
georgehifi's Avatar
Send a message via MSN to georgehifi
I did test the waters about 4 years ago to see if a kit was viable, not with members of this forum just from audiophiles who emailed me who wanted a production Lightspeed Attenuator but found it too expensive for them at $450 posted. They ended up spending $280 + post which is usually around $50 insured world wide postage total $330 for a complete kit which included everything even the $60 extruded aluminium chassis, and knob and Lightspeed decals.
Out of the ten test kits I sent out 6 kits came back because of ham fisted solders that cooked the quad matched NSL32SR2S and put them so far out of calibration some had to be binned, or they had no idea how to thermally couple all 4 NSL32SR2S together and pot them so they stay thermally stable. The other one was they did not have access to an oscilloscope and audio generator to do the final calibration so I had nearly all of the complaining about channel imbalance.
Now out of the hundreds of production Lightspeed Attenuators I have shipped out, to some crazy places Guam?, and Macedonia?, just to name two, not one has come back, so you may now see why I am reluctant to do kits, but hey if someone wants to give themselves a real headache give me a reasonable offer for the licensing rights do a Lightspeed Attenuator kit I'm all ears.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 25th April 2010, 05:56 AM   #284
parb is offline parb  Singapore
george,
even if your experiences with the kit world isn't the best -i still wish to commend you for your design and even if i personally prefer to 'cook my ldr's' myself (or perhaps i'm a better solder than that) i still wish to recognize you for your work and most of all... i think you're a good man for sharing with the community.
Old 27th April 2010, 12:35 AM   #285
joemana is offline joemana  United States
I’ve tested my Lightspeed with signal generator and dual trace scope, I put the trace at the top of the other with the signal almost exactly the same as I adjust the volume pot, but before it reach the max volume, one of the signal clipped ( I really don’t care since I may not even use up to the 2/3 of the volume pot) I’m only curious what could be the cause of clipping?
I hooked to the Source and Amp and it sounds good especially on the high side. Does the lightspeed makes the sound a little bit thinner or it just boost the high?
Now, I only need to find out how can make it to work with remote and dual input..
Thank you very much George and Oliver.
Joe
Old 27th April 2010, 11:58 AM   #286
Joe
Hi Joe,
i couldn´t answer your question about the clipping, but i found a real cool solution for the remote control request.
Click the image to open in full size. Click the image to open in full size.
This Kit HERE from diyclub use a 100K Alps motorized pot and has a 4 channel single end input, selected by relay.
So everything you want to have...
Best regards,
Oliver
Old 27th April 2010, 09:37 PM   #287
Joe
Can't answer your distortion question, but I HAVE solved the remote control/multi input one. But it involves cutting a couple of traces and careful soldering.
I'm not sure if this should be in a new thread..I'll give a "quickie" overview here:
Get this remote volume/multi-input kit from Hong Kong Remote Control Volume for DIY tube Preamp Amplifer 100K - eBay (item 220428580361 end time Apr-30-10 22:47:27 PDT)
Costs $70 including shipping to USA. Cut traces with a dremel or utility knife - I have pix of the work if anyone wants to see. You can then have IR remote vol & input switching.
Old 27th April 2010, 10:17 PM   #288
Keep in mind you CANNOT just "drop this in" and expect it to work. It won't! You HAVE to cut traces! The ground from this remote board has to be disconnected from the motorized pot. Remember, you are going to put +5V thru the pot & you'll destroy your power supply because the pot is connected to the board's ground.
Beware...but it DOES work great if you do it correctly.
Also, note that my link goes to a board that's a little different from dvb's. They aren't exactly the same, but I'd bet the other board also ties the pot to gnd.Batchme001.jpg
Last edited by windowman99; 27th April 2010 at 10:29 PM. Reason: add pix, two different boards
Old 2nd May 2010, 01:21 AM   #289
[QUOTE=windowman99;2168332]Keep in mind you CANNOT just "drop this in" and expect it to work. It won't! You HAVE to cut traces! The ground from this remote board has to be disconnected from the motorized pot. Remember, you are going to put +5V thru the pot & you'll destroy your power supply because the pot is connected to the board's ground.
Hi windowman,
Thanks for the links. Do they have manual ? I read some comments from those who bought the products that the seller don't provide the manual.
Do you think that kit is better than Danzup's kit ?
Thanks,
Joe
Old 2nd May 2010, 11:01 AM   #290
Hi windowman,
Thanks,
Joe[/QUOTE]
Joe,
Yes, there's a rather crude set of instructions in broken English with labeled pictures. But inexplicably, they don't include it with the product. You have to ask for it, and fortunately it gets sent via e-mail. It's adequate enough to get the basic job done. Note, it does NOT go into the mods needed that I'm talking about for remote LDR use.
Never heard of "Danzup's kit". Can you give some more details and maybe a link to the info?
Poor Serbian Man Optical Volume Control Zen Mod Analog Line Level 416 21st May 2011 05:31 AM
Volume pot/buffer/optical control jonnoh Solid State 5 10th April 2010 01:37 PM
Optical Rotary Encoder Volume Control unit using the Grayhill 62P DJ Exprice Everything Else 17 1st January 2008 08:50 PM
Digital volume control with remote and optical S/PDIF DEQ+TheEnd Digital Source 0 21st November 2005 03:58 PM
Page generated in 0.15444 seconds (82.00% PHP - 18.00% MySQL) with 12 queries
