| Group Buys Members group buys |
This project had been on the back burner for some time. It is a very sophisticated High Voltage Shunt regulator PCB. I think it is an original Allen Wright's design. It can be use with an external power tube or as stand-alone. I made my own PCB using his schematic and parts list. I found the original documentation on the net, but it seems to be gone now. It took me some time to collect all the parts but I found them.
Been on the road again, I found some time to complete the PCB. I'm planning to use it into my upcoming EAR824P Phono preamp clone. I have two complete PCB completed. Just need to test it now. Since it is not my design, and it is a brand new project I cannot answer any question on this circuit. I need to work on it first. The manual http://basenjes.de/tubes/data/sb/Shu...SB%20Notes.pdf This is the top view. |
#2 |
And the PCB bottom view.
#3 |
My own parts list.
#4 |
And my PCB parts silkscreen.
#5 |
what about the schematic?
TIA, |
#6 |
I forgot
... Here it is.
#7 |
Just looking at the schematic, that's not Allen Wright's design - it is in fact Emile Sprenger's HPHV regulator, which is a very well-designed shunt regulator with a similar overall architecture to Allen's SuperReg. I use a couple in my RTP3C preamp, as well as in the active crossover I am in the middle of building right now.
Alex |
#8 |
Thanks for the precision. I was looking for the original designer, but I couldn't find the original website.
#9 |
Hi Alga_emi
The original manual says DUE TO THE SPECIAL (DUAL) POWER PINS/CONNECTIONS OF THE OPA655P, DO NOT SUBSITITUTE THIS DEVICE WITH ANOTHER OPAMP. Did you adjust the design for opa656u as in your BOM? I wanted to build this shunt regular for the longest time but had no chance to locate the ops655p. Thanks!!
- Fred - |
#10 |
In my latest builds of the HPHV I used AD9631 instead of OPA655. These are high-performance op-amps with standard single power connections, and - more crucially - there is no facility for external compensatin or offset nulling, so pins 1 and 8 are not connected internally. I haven't tested my regulators with an oscilloscope, so I can't rule out ultrasonic problems, but they appear to be working fine.
Alex |
| How about shunt regulatorH | uhcmos | Solid State | 4 | 2nd March 2007 09:32 AM |
| Shunt regulator | tubee | Tubes / Valves | 12 | 2nd March 2006 01:08 PM |
| Page generated in 0.08985 seconds (69.47% PHP - 30.53% MySQL) with 11 queries |
