Hi all. Joe has had a few issues with his B200s. None of the published solutions worked for him. He has given the attached line level passive network a try, and he has left the ribbons off.
No attempt has been made to correct the bass roll-off on his OBs, the bass helper does that. This circuit could be used on other baffle arrangements. Over to you Joe, when you get away from Miss Jones. Geoff. |
#2 |
http://www.audiocircle.com/circles/i...?topic=31582.0
A very good thread for that, and the OB forum has lots of information on the B200 |
#3 |
I used this to tame the shout of my Monacor SPH-30X quite successfully:
http://www.audioasylum.com/forums/hu...es/120394.html only I placed a potmeter on R3 to adjust the effect, it functions more or less like a midrange eq. fader...but once adjusted I never feel the need to change it again...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... |
#4 |
Step 1 -- phase plugs...
dave planet10/ of course i have a bias
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Here's what worked well on the Monacor:
#6 |
Hi Dave, thanks for your great input!
#7 |
Hi Dave, one thing at a time. The ribbons are off. He must still be with Norah.
#9 |
Though I reserve the term "shout" for whizzer coned drivers, the B200's do beam and have that long gradually rising response. Below is my solution to both. I call them Constant Directivity Dipole WaveGuides (CDDWG's). The narrower dispersion helps match the lower end response with the HF beaming to sound flatter overall. HornResp tells me there's even a few db gain from some slight horn loading below 1khz, which also helps out. When the waveguide runs out of steam, the dipole directivity takes over. I use them with dipole bass augmentation, but they work surprizingly well run full range with a little bass boost.
BTW, Dave I picked up a used pair of 167's that have your phase plugs. Will those fit a B200, since it has the same VC diameter?
Everyone has a photographic memory. It's just that most are out of film. |
#10 |
I like my phase plugs from Dave for the B200. The sure help the beaming. The rising response can be help with toeing in or out, a notch filter, or hopefully the new toy John is showing.
| F/S Visaton B200 | nvrgdenuf | Swap Meet | 4 | 31st August 2009 03:02 PM |
| Visaton B200 (x2) - UK | Grumpy_Git | Swap Meet | 6 | 17th September 2008 12:31 PM |
| where can I buy Visaton B200 in USA | ken mead | Full Range | 2 | 22nd May 2008 12:06 PM |
| Visaton B200 in BIB | Rafal | Full Range | 5 | 23rd November 2006 08:40 AM |
| FS Visaton B200 | JohnnyBoy | Swap Meet | 3 | 24th October 2006 03:35 PM |
| Page generated in 0.11316 seconds (80.72% PHP - 19.28% MySQL) with 11 queries |
