| Thread Tools | Search this Thread |
#951 |
Hmm, it does appear to be a flared vent, offset driver, TL of sorts, but the driver filter chamber makes it more of a funky BLH than the Metronome's simple vented pipe horn.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#952 | |
some of those funkier B&W designs kinda make ya wonder whether a group of them drank the bong water after the staff Christmas party
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#953 |
#954 |
i [sadly unemployed for the moment] managed to score a sheet of nice birch from a buddy's cabinet shop scrap bin.
i had to have a pair of these. the only drivers i had handy were the Tang Band w4-1052sdf i know the enclosure is not optimal for this driver, but i could not wait and ripped a pair out using the 4" recommended design. they sound amazing...mostly. i have no bsc but a little EQ in foobar and they are really pleasing to me. my real issue comes from a strange harmonic vibration at the top of the enclosure...a buzzing sound. not really sure how to correct this without destroying the enclosure to dampen that area more or add bracing. any ideas? the resonance occurs in the upper range of some male vocals. and yes i will re-stain them. wife is deciding on that soon. please forgive my noobish construction and crappy camera phone.
#955 |
So, after running all the sims over and over again for the ff165wk, I had mustered enough courage to actually build the enclosure (or to be more precise, have the enclosure built by a professional carpenter).
Below are some pics of the build during dry fitting just to get a peak at what it'll look like. I ended up redesigning the feet, giving them a more "modern" look that'll better go with my listening room. The enclosures are made out of 18mm marine plywood, CNC cut down to 1/10mm precision. As you can see on the leg closeup, I made a design mistakes and did not account for the plywood thickness when drawing the side panels, which left me with a step from front panel to side panel at the leg level.... well you live and learn. Paint should be done by tuesday, will post more pics then... Regards Nick P.S: sorry for the bad pic quality, but there's only so much one can do with a crappy phone camera... |
#956 |
Here they are, finished and singing...
I ended up lining the inside of the back panel with acoustic foam from top to bottom, and am now in the process of voicing them by adjusting the stuffing in the upper part of the line (above the driver). So far, they image like no speaker I've ever heard before! Another thing is that they definitely need a BSC filter, but i'll do that once i'm finished with the break in (30 hours down, another hundred hours or so to go...) and once i get my measurement rig up and running The ff165wk are very smooth drivers compared to the usual full ranger i'm used to and i can't say they're lacking in the upper registers.... I'm a happy happy metronome owner. Thanks Dave, Scott and Steve... back to my music |
#957 |
Glad you like them!
Those asymmetric base arches look cool Steve |
#958 |
#959 |
I've read through most of this thread with great interest- Back in the 320-ish post, there were some numbers posted for a 15 inch coax driver that is somewhat similar to a pair of woofers I have on hand- the Faital 15PR400- similar Fs at 35 Hz, but different Qts, at .30. I was going to throw them into a standard reflex enclosure, but that's boring- I think these would be great in a ML-QQWT. They aren't full range woofers, but with good response to 4K, they will reach well up to my paper horns…
Can anyone help with a set of numbers for these? Actually, just checked back- it was post 206… For a PAudio BM15CX38. I could just try and drop these in… Last edited by Corvus corax; 16th April 2012 at 02:37 AM. Reason: added info. |
#960 |
It would be a bit undersized to my way of thinking and need a 3" long vent for a similar response, so consider a ~432.76"^2 base area, ~1.5" long vent and driver down ~39.88".
GM
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| NcHalfrican, hajj |
| A11 Metronome possible? | tigh4life | Full Range | 1 | 12th July 2011 07:17 PM |
| Page generated in 0.09985 seconds (70.45% PHP - 29.55% MySQL) with 11 queries |
