Full Range Speaker Photo Gallery
Old 15th May 2010, 08:24 PM   #1201
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Just got my hONKEN (fONKEN boxes with HiVi B3N) speakers finished (almost).
I am perfectly happy and VERY surprised that they play that low. Maybe they sound a bit constrained but I am used to my exponential horns (5" Sonido).
Will swap the screws.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 15th May 2010, 09:16 PM   #1202
doorman is offline doorman  Canada
doorman's Avatar
Good Job, Magnus!
Old 15th May 2010, 09:23 PM   #1203
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Yes very nice indeed. At least here I get to see them as well as read about them!
Thetubeguy1954 (Tom Scata)
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 16th May 2010, 06:32 AM   #1204
However, I had the pieces cut out at the "wooden hobby circle", glued them together and "routed" away some extras at home why the final result wasn't the most perfect. But just for hooking up to a small amp and listen to Youtube, they are perfect.
/Magnus
Old 17th May 2010, 11:26 AM   #1205
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Default My zigmahornets ... with black Coral holey baskets
Though I haven't heard Zigmahornets with the Merrill drivers, I have to say I'm pretty impressed with the holey baskets.
I don't know whether there is any audible difference between the black and the beige HB's. I may swap in a pair after I've listened to these for a few weeks.
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 17th May 2010, 11:33 AM   #1206
Brisso57's Avatar
Default Detail of the grilles (red cedar)
The reason for the wide grilles is obvious.
A case of making a virtue of a necessity!
cheers
Doug
Old 18th May 2010, 02:14 PM   #1207
hesener is offline hesener  Germany
Default OB speakers with SEAS F8
Hi, here my OB speakers with the SEAS F8 / not exactly beautiful or well-made, but the sound is great. I am looking forward to making a nicer baffle going forward.....
size is 40" x 20", the speaker is located in the center of the upper half. The two "U" sides are 8" deep. The filter is a 0.82mH air inductor with 10Ohm resistor in parallel.
Old 18th May 2010, 03:26 PM   #1208
Hello Hesener!
They're not exactly ugly or just slapped together either! Heck either a nice paint job or some veneer and they'd be quite nice indeed! Besides that the sound is great!
Yes, you can certainly look forward to making a nicer baffle in the future, but enjoy listening to what you have now.
Old 19th May 2010, 07:07 AM   #1209
omegaspeedy is offline omegaspeedy  New Zealand
Default My Visaton B-200's
These are my B-200's in what started as an Omega A8 replica but have evolved into something far different. No Aperiodic port, a resonant 18mm floating ply back panel (four brass screws and rubber washers securing it) and an unloaded port of 240 by 70mm's. Overall size, 280, 370, 510mm (W,D,H). Filter is Mundorf foil/air wound 1mH inductor and M-restist 8.2ohm resistor in parallel. Resonance control is bitumin pads and 2" flat foam top and bottom and 1" Foam on the side walls and contoured foam on rear panel.
They sound stunning through the little Dayens Ampino. It has taken over 6 months of experimenting and tweeking with different materials, thickness, port sizes, filter components and I almost gave it away several times, but I'm glad I didn't. The rewards are well worth it when you get it right with the B-200. Don't give up on them! I know OB would have been easier but now I have a compact that sound incredible. Response is 55hz to natural roll off and I don't feel I need tweeters.
Old 19th May 2010, 06:49 PM   #1210
pathdoc2 is offline pathdoc2  United States
Nice looking cabs, omegaspeedy.
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
