Hi !
I search to build a fullrange speaker 3 or 4"
I want impressive low frequency with high power handing !
And all this for CHEAP price and available product in north america.
Thanks in advance to send me your best brands and model
nicK
Hahahahahahaha!!!
Wake up and smell reality, man.
I like these guys. Not bad for the price..
Tectonic Elements TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm
Perhaps they are good (they sure are interesting), but they won't go low, nor will they go loud.
Markaudio FR speakers combine small and good bass, but they won't be loud. And they are refined products with a price tag to match.
It can be done, but it will be a large horn speaker. And for the price of that cabinet, you could easily buy a good large driver.
OMFR Speaker - One More (folded-horn) Full-Range Speaker system : Connecting the speaker driver
How about a pair of Fostex FE126en in a FH Mk3 box made of foam-core and hot glue? Cheaper, they'll play loud, and easy to build. I've never heard them so I don't know about good bass, but I may try it myself. I did a scaled down version of it and it was pretty good even that way. The box was 12x12x6 internally.
Why you laugh at me !!!???
AYE ! C'MON GUYS !!!
Exemple = BOSE reach to get good results with a VERY CHEAP speaker.
Okay okay I don't search to make 100dB at 20hz with 3-4" driver I'm not idiot !!!
I just want to know your best result with one small driver !?
Exemple Fullrange ; HI-VI RESEARCH C3N-III or B3N or
Thanks in advance !
nicK
Thanks in advance !
nicK
You can get quality bass from 3.5in - just play at moderate levels
You mean like this? I did it with the $12 Vifa TC9FD which sounds quite nice. Bass is in the 60Hz range.
http://www.diyaudio.com/forums/full-range/227460-fh3-inspired-foam-core-mini-build.html
It's a fun speaker and great sounding too. The TC9FD, although with only a 120Hz fs, can reach low due to its high Qts of 0.89. I have used this driver in many different alignments where you normally would not think of using a high Qts driver and many times it works very well. Perhaps the highest quality bass (at moderate SPL levels) was achieved with the TC9FD in dual chamber reflex (DCR). I got about 55Hz with fairly low distortion when listening near-field at sub 80dB SPL.
More info on DCR here:
http://www.diyaudio.com/forums/full-range/252627-viva-la-vifa-curvy-cabinet-dcr-tc9fd.html
Plan:
Here are measurements of DCR with TC9FD:
Impulse Response:
Polar response for unit 1 & 2:
Listen to it here:
http://www.diyaudio.com/forums/attachments/full-range/406143d1394939982-viva-la-vifa-curvy-cabinet-dcr-tc9fd-dcr-vifa-clip-real-bsc-06.zip
Plan:
Impulse Response:
Listen to it here:
Hi again !
This speaker seems to be really good
But parts-express is really expensive shipping price to Canada
If I find the Canadian distributor maybe try this interesting driver.
it's good to see your really BEAUTIFUL SMALL project with the spec sheet ! THANK YOU ALL !
Hoffman's Iron Law: Small -- Loud -- Low. Pick two.
If you want cheap, you probably will only get small.
Bob
I thought 'small' applied to enclosure size as opposed to driver size?
This one gives a lot of bang for the buck and can be ordered in Canada.
Creative Sound - Product Details
Mike
Mike
How do you bend the foam-core? What I have is way too stiff.
It's called "kerfing".
https://www.google.com.tw/search?q=...v&sa=X&ei=RwBRVI_YH9CxogSPiYKYBA&ved=0CCgQsAQ
True, but bass from a 3" driver is an oxymoron. But then the OP could supply real specs rather than just a killer speaker. Room size, expected SPL at what distance, F3/F10, and anything else that would provide for meaningful suggestions.
Bob
- define dollar range for "cheap"
- my personal favorite / most impressive full-range in this size range is still the FF85WK - but there are literally too many for most guys to actually audition
-yes, international shipping and brokerage, etc charges can easily double the landed cost of a small purchase - that's life
-the Vifa of which xrk is a big fan looks to be good candidate
- Full Range
- your most impressive cheap fullrange 3-4" (low bass)
