I will most probably have one single Mark Audio Alpair 10.3 (Grey) left over from a build of x7 bookshelf speakers.
My System is 50/50 music/movies, although the projector for which I use sits on the hi-fi and fires onto the other wall, with the speakers firing from behind, so not ideal, adding a centre speakers would seem silly unless I had it beneath the screen, which isn't that feasible.
I guess I could buy a second and make a pair of speakers, but before I do, any bright ideas for one single (amazing) full range driver.
So far I can think of a centre speaker,
Perhaps making a small bedroom radio/iphone dock
Some omni experiment?
Anyone else had any brainwaves for those odd left overs.
Small bedroom radio, definitely. Perfect for some background music. Or why not have it in the kitchen so you can enjoy some good music while cooking?
Make a nice high fidelity mono table radio or iPod dock. Use the Karlsonator cabinet - that thing has great bass, natural sounding, and very broad directivity. Check out the Mini Karlsonator thread, I can run sim for you with A10 - it will probably make a nice compact cabinet. You will need a summing opamp to get stereo to combine to mono.
Yeah, I even have a redundant Raspberry Pi (can airplay to it) And a spare Class T-amp (sounds rubbish with the revealing alpairs though)
Could try and marry something inbetween this by Davone
And this Dieter Rams inspired design
oooh, I have to strip out an old valve radio, could this be repurposed and used for a 'boombox'. Will take some pictures of it and see if the radio input can be switched for something more modern.
looks similar in design to this one I just found on eBay
MONO Valve amplifier , ( Two Valve ).... complete with speaker on Baffle Board | eBay
I have been enjoying the mono thing for a while now. When space and money are low this is a decent way to get good sound (and play with great drivers). I expect to go back to stereo eventually but for now, this is fun enough.
Zilla
Zilla
Joined 2009
I went mono for main listening over a year ago. I'm only sorry I didn't realize the benefits earlier. I now find most stereo very false sounding, variable between sources and more demanding of room layout and seating. The only place I have stereo now is my computer since it's easy to control seating etc. but for my main music pleasure I find mono the best. Of course, for home theatre I have all the speakers but that's a different kettle of fish.
Rather than find a way to use up your spare driver why not 'aim high' and try and make the best quality mono system that you can. My thoughts would be MLTL (no particular design in mind) or open baffle. When you only have to make one of everything you can lavish a bit more attention to it.
Pair it with a really good amplifier - perhaps a triode.
Any plans for a centre speaker with a low cut off?
I'm, thinking of making something simlilar to the B&W Zepplin, but with a baffle of solid wood. I think it could look stunning. Hide a Raspberry Pi in there and have some small chip amp or valve monoblock.
So any great designs that would work?
So here is the plan.
Raspberry Pi, (running xbmc or perhaps raspberryFi) - Mini Digi - Mini DSP - Mini Amp.
1 Alpair 10.3 in some sort of cabinet, and perhaps a small long through woofer or two.
Ive found these 5" Tangband subs on eBay for £14ea
Tangband W5-876SD
I was thinking use the dsp and have two (maybe three?) of these to handle the lower frequency, and have the Alpair in a sealed enclosure.
Just need some nice ideas for cabinet shape.
Im keen to use the CNC machine to make sexy curved back panels and have a solid shaped baffle ala Zeppelin
Or square it off and make it more danish modern, Dieter Rams esc.
Tangband W5-876SD
You'll need a USB to TOSLINK/SPDIF DAC or similar to sit between the Pi and the miniDigi.
Sounds like a fun project. Is the sub really necessary with the A10? They had no trouble making bass in all the enclosures I have heard them in (P10 designs). I suppose it depends on the space and your tastes.
Kyle
Kyle, as deep as the A10s can dig, it never hurts to relieve any FR of heaviest lifting and add woofers
How does the A10 model in a sealed box? Is there a savings in volume that can be put towards a support woofer?
KM
KM
that's a question for the measurement / modeling guys, put I can say that the 10.3s don't go as low as the 10.2s
probably moot though as most XOs to support woofer I've seen for such set-ups have been well above (octave or more) the beginning of wide-band driver's roll-off
I thought I could do optical out from the Pi into the minidigi.
Could be good to try and squeeze the most out of a small box.
There's no optical out on the Pi sadly. Just a crappy quality 3.5mm head phone jack and HDMI.
The Planet 10 CGR Mar-Ken 10.2 is fairly compact.
KM
Slightly OT but there's a great looking single-board-computer in the works called the Cubbie Truck: Link . The company already has a similar board in production and this is a larger and better equipped version featuring a Optical output and a SATA connection for a hard drive. Looks like it'd be a really good candidate for a music server.
KM
Which A10?
A10.2, A10.3, A10p
dave
- Full Range
- What to do with one spare Alpair 10.3
