SB 8 inch woofer sounds great on its own. - Page 4 - diyAudio
Old 19th January 2013, 04:05 PM   #31
xrk971 is offline xrk971  United States
xrk971's Avatar
I was asking myself the same thing, if indeed that is a Pensil A12 in the picture. Smaller drivers have better imaging in general so not surprising.
Old 19th January 2013, 06:22 PM   #32
The pensil's sound better in the bass department but the crispness of the MA 7.3,even in a foam core box, really shines. I will work crossover experiments while woofers are breaking in.
John
Old 19th January 2013, 08:21 PM   #33
mor2bz is offline mor2bz  United States
again, what is a sb woofer? i pasted the numbers and came up with nothing but your post.
thanks
Old 19th January 2013, 08:36 PM   #34
SB Acoustics. You will it at Madisound.
Old 19th January 2013, 10:58 PM   #35
tuxedocivic's Avatar
Is your enclosure sealed? Interested to know how you find the bass once they're in a ported or something enclosure.
Old 20th January 2013, 04:22 PM   #36
It was "sealed" but then I cut a couple of crude ports in the front of each. It was an improvement. Inserted paper towel rolls and another improvement! It's a great way to learn but the WAF is a new low.
John
Old 20th January 2013, 05:01 PM   #37
xrk971's Avatar
WAF can be high with foam core wall mount cornu horns. Hey at least they are not full BLH with front tractrix horns I read somewhere those were a sure sign of either celibacy or imminent divorce
Old 20th January 2013, 09:46 PM   #38
frugal-phile(tm)
planet10's Avatar
I did some sims of this and decided 55 litres would work well.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2013, 11:23 PM   #39
Dave, was that ported or sealed? That's a fairly large speaker, so hopefully ported. Lots of bass??
Old 20th January 2013, 11:33 PM   #40
frugal-phile(tm)
planet10's Avatar
Ported, aligned for high aspect ratio vents. actually smaller than what i'd use sealed (60 litre). Sealed Q = 0.5 is over 100 litres.
dave
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 12:01 PM
4 inch driver sounds better than $1000 ror Full Range 101 9th November 2010 06:32 PM
Sounds like a great deal from a great guy mikejennens Chip Amps 0 2nd February 2010 11:17 PM
Pentode sounds great Cassiel Tubes / Valves 15 31st August 2008 10:23 PM
sounds great, thanks to everyone that helped. Richie V6 Chip Amps 6 1st January 2005 03:06 PM
Copyright 1999-2017 diyAudio
