Old 18th January 2013, 08:59 PM   #11
tuxedocivic's Avatar
Ya, don't cross at 1000hz. Here is what I do. If you want a prescription, follow this. If you don't, read and ask questions.
Buy a minidsp.
You'll need 4 channels of amplification. (if your receiver is integrated, this might be an issue)
Get the 2 way plug in (the advanced biquad plug in is better, but it's all features you won't need and will only confuse you)
Build a large ported box with the help of those here. I can try.
Build the box to include a 5 to 7L sealed enclosure inside for the alpair 7 near to the mounting hole of the SB woofer.
All that make sense so far?
Once you have the speaker built, you'll need to hook everything up. Preamp - minidsp - amplifiers - drivers.
You'll also need to program the minidsp. I can help you with that, but it's pretty easy. Just install the plug in, make the setting changes, and sync to your mini.
For starters, I'd suggest these settings.
Woofer
Level = 0db
Delay = 0ms
Low Pass = Linkwitz Riley 24db/octave at 300hz
PEQ = none needed
Full range
Level = 0
Delay = 0.6ms
High Pass = Linkwitz Riley 24db/oct at 300hz
PEQ = 6000hz, -2db, q = 3.0
Start with that and see how it goes. If it's bloated, the woofer level may need to be -1 or -2.
Old 18th January 2013, 09:25 PM   #12
frugal-phile(tm)
planet10's Avatar
That is probably an OK start, but in the end you want to dial in the XO sucj that a simple change of woofer level can be used for BSC.
I have founf that that puts the XO in the K x 4560/(width of box in inches) K is in the range root(2)/2 > 1
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th January 2013, 09:37 PM   #13
I was thinking a 10" box is pretty likely for him. So 300hz was my first stab. I've also found with Linkwitz Riley slopes, the simple raising/lowering of the woofer achieves exactly as you say, BSC. Butterworth is to high of Q at the knee of the slope to allow for that.
There's the 6db of baffle loss, but then there's the 1 to 2db of cab diffraction right at the top of the baffle step point. I often find the diffraction to be a bigger deal than the baffle step actually. So he may need a PEQ of 650hz, -2, 1.0q.
EDIT - You may recall from the measurements I gave you on the SDX7 / LD25x speaker a wicked little diffraction peak around 650hz. You remember the baffle width of that one off hand? I couldn't take that out with a passive filter. At least not without a pricey notch.
Old 18th January 2013, 09:45 PM   #14
Scottmoose's Avatar
Don't be such a Jessie. You haven't seen some of the XOs I occasionally crank out. You'd never complain about pricy notch filters again, I promise you that.
Old 18th January 2013, 09:49 PM   #15
Hehe, well, if I have a 2mH inductor on hand, then maybe I'd do it. But kills me to spend $10 on 2 db That's not a very good hifi mentality is it. Long live active dsp!
Old 18th January 2013, 10:16 PM   #16
Great suggestions but right now all I have is two channels of 8W each. I do, however, have plenty of foam core so I will build my test/break-in boxes and begin the learning process. Stay tuned!
John
Old 18th January 2013, 11:53 PM   #17
frugal-phile(tm)
planet10's Avatar
About the same width as the waveguide.
Since a diffration anomaly will be very much listener axis dependent, kinda hard to EQ it.
dave
Old 19th January 2013, 01:06 AM   #18
Oh it's higher in frequency than I remembered.
Ya, it is a little awkward to eq diffraction. Often ok left alone.
Old 19th January 2013, 01:17 AM   #19
OK. Had way too much fun making 1 cu ft foam core cabinets and am now listening to my creation with a crude 1000hz
first order cross over consisting of a 1.5mH inductor on the woofer and a 22uF film cap on the MA 7.3. Sounds gorgeous! The cab, if you can call it that, is 20" tall by 12" wide by 9" deep with a bit of poly fill and no vent. I have them sitting on the floor toed in a bit and Gillian Welch has never sounded better. I am new to this so I am willing to call this a starting point. Anyone want to suggest incremental changes that I can easily implement? It is minus 15 Celsius here in St.John's, Newfoundland, and it is a great way to spend a Friday evening. Thanks to all!
John
Old 19th January 2013, 01:19 AM   #20
That pic didn't turn out so well. Here's another.
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 12:01 PM
4 inch driver sounds better than $1000 ror Full Range 101 9th November 2010 06:32 PM
Sounds like a great deal from a great guy mikje Chip Amps 0 2nd February 2010 11:17 PM
Pentode sounds great Cassiel Tubes / Valves 15 31st August 2008 10:23 PM
sounds great, thanks to everyone that helped. Richie V6 Chip Amps 6 1st January 2005 03:06 PM
Copyright ©1999-2013 diyAudio
