The Supernova! (a full range flooder line source) - Page 10 - diyAudio
Old 10th December 2012, 08:05 PM   #91
mondogenerator's Avatar
perhaps im mistaken then. I thought Elias' speaker was just L and R. Either way I havent listened to or built his speaker. Just my impression looking in from outside, without having tried it
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th December 2012, 09:25 PM   #92
norman bates's Avatar
you can always try the left speaker, summed left + right speaker, and right speaker.
Just use 3 drivers and play with levels, play with a squeek of delay.
Yes race won't be there, but it gives a solid center and a panned left/right, versus a diffuse center.
Norman
Old 10th December 2012, 11:52 PM   #93
Melo theory's Avatar
Look at the size of this bugger!
I have a new name for it. The "Ambiolith"
We have a monolith....we have a stereolith, we now have the...
AMBIOLITH...LITH...LITH...LITH
haha!
I LIKE YOU
Old 13th December 2012, 01:53 PM   #94
Elias is offline Elias  Finland
Elias's Avatar
Looks like you've done an overly wide and tall stereolith without the tweeter
You should have put a third line in the center and used the matrix
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th December 2012, 02:30 PM   #95
adason is offline adason  United States
adason's Avatar
its impressive, but why did you make it black? why not white...it could have been less visible
Old 13th December 2012, 04:55 PM   #96
- Elias
Yeah. I wanted to test the flooder theory first, to see if I would get good separation. I did, but only in the FR of about 3kHz and up, and to tell you the truth my heart was in an omni design in the first place because I knew there would be a mismatch between RACE and the reflected signal.
I will try the matrix theory with larger full ranger point source drivers. Maybe I will just clone yours and see how it sounds.
I LIKE YOU
Old 13th December 2012, 04:57 PM   #97
Ever since I saw 2001 space odyssey, I wanted a monolith as a design statement! I'm not kidding about this
I LIKE YOU
Old 13th December 2012, 06:25 PM   #98
Colin is offline Colin  United Kingdom
My god, it's full of stars…
Old 13th December 2012, 08:00 PM   #99
Elias's Avatar
Originally Posted by Melo theory View Post
If I went with the matrixed center, that wouldn't help to push mid frequencies to the sides.
Wrong, because perceptually the mid freqs are coming from the side if you'll use the matrix x=0.5.
This is one of the scenarios where traditional precedence effect breaks down.
See this simulation. Here the stereo signal is fully panned to the left side. Note the direct sound is much weaker than the sound reflected from the left wall. Reflection overrules the leaked direct sound, and stereo is enabled.
Elias Pekonen Home Page - FDTD simulations on Single Speaker Stereo SSS
- Elias
Old 13th December 2012, 08:07 PM   #100
Elias's Avatar
Yes exactly there is no way to steer the midrange freqs by only using 2 drivers. You'll need 3 drivers and the matrix. Then only a vector is formulated which can be steered by the stereo panning.
- Elias
Need T-Line help for Full Range T-Line wanton Full Range 35 11th November 2012 08:37 PM
Source for full-range drivers for DJ headphone project? jkantor Headphone Systems 0 24th June 2011 03:08 AM
Dayton Point Source Full-Range Neo Drivers bluegti Full Range 2 13th November 2010 07:49 AM
Full range line array inrank Full Range 39 20th January 2009 01:27 PM
Full-range line array? mazeroth Full Range 20 1st November 2004 04:47 PM
Copyright 1999-2017 diyAudio
