Alpair12P gen2 standmount speakers
Old 26th September 2012, 10:47 PM   #131
toobhed is offline toobhed  United States
Vaughn,
The amp, speaker set and diffusers are simply stunning! Don't worry about the toddlers, they'll find other toys (but hopefully not the speakers' vc dust covers....)
Mario
Old 26th September 2012, 11:47 PM   #132
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
try the super cheapie Radio Shack
These are the ones:
Phono Plug (8-Pack) : Phono Plugs | RadioShack.com
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th September 2012, 05:45 PM   #133
chrisb is offline chrisb
Originally Posted by planet10 View Post
The biggest issue with CAT5 solid is it's tendency to fatigue with frequent flexing for which it's not designed.
FWIW, I prefer the soft plastic extended sleeve when simply twisting or braiding 2 or 3 conductors of this wire - a couple of layers of adhesive heatshrink inside and out gives you pretty good strain relief.
Those shown above have a larger opening in the plastic cover and are great if you're using hemp rope, cotton shoelaces, aquarium hose etc as sleeving or core - more desirable if you're planning on lots of plugging & unplugging
like my mind, this space intentionally blank
Old 7th December 2012, 08:22 AM   #134
zman01 is online now zman01  Bangladesh
Default Few mm wider and shallow...
Scott,
I have a pair of A12 DBR boxes which I might be able to convert into the A12small BR box (also dubbed as Moose Monitors).
I will end up having a baffle which is ~26mm wider; I can reduce side length to keep the box overall volume same.
Should be ok?
- Zia
Old 9th December 2012, 07:43 AM   #135
Toppsy is offline Toppsy  United Kingdom
Zia,
Scott may be busy with other things that has prevented him replying.
As long as you keep to the same internal volume the extra 26mm wider baffle should be OK. It might have a small impact on reduced imaging but this could be minor and could be not at all. You can always cut a 45-deg chamfer around the front baffle if you like.
When Scott sent me the design he only gave me the volume and port details. I ended up with the size of box that Scott and I published from playing around with CAD and several different sized boxes that gave the same volume. To my eyes the published box gave the most eye pleasing result.
Hope this helps.
Old 9th December 2012, 10:24 AM   #136
Thanks Colin.
I was also thinking about the good old 45 degree chamfer trick - usually manages to make any box look thinner.
- Zia
Old 29th March 2013, 08:58 AM   #137
almuse is offline almuse  China
My 12P:
Old 12th May 2013, 11:46 PM   #138
murphythecat8 is offline murphythecat8  Canada
okay, im doing those speakers this week, wish me luck!
just to be sure, post 53 http://www.diyaudio.com/forums/marka...ml#post3140404, is the one to follow for the dimensions?
Old 13th May 2013, 02:17 AM   #139
Yes. Plans:
http://www.madisound.com/pdf/SmallRe...22p-191012.pdf
For the baffle you will need 1" thickness with the A12P. With a 18-19mm board you will be left with 6-7mm after doing the rebate for the driver, and that is probably too less. I added a 6mm layer to the 18mm ply I had; Two layers of 1/2" ply should work too.
Old 14th May 2013, 03:36 PM   #140
k thanks. Now, due to my WAF, I may not be able to go one with my plans, dammit! I'll keep on trying to convince her, but I understand
Alpair12P gen2 standmount speakersHide this!Advertise here!
FS: 2-way Standmount speakers glenh Swap Meet 0 3rd April 2012 04:24 PM
SR551-HDS -- 2-way standmount gornir Multi-Way 12 21st November 2011 05:20 PM
WTB: Gen2 Maelstrom-X 18 notnyt Swap Meet 0 2nd February 2011 04:54 AM
1kW Gen2 ChocoHolic Class D 90 10th August 2008 02:45 PM
Modding the Gen2 Sonic Impact loninappleton Chip Amps 2 8th May 2008 01:21 AM
