Please recommend a desktop fullranger?
Old 8th August 2012, 07:55 PM   #21
tvrgeek is offline tvrgeek  United States
Originally Posted by planet10 View Post
Actually laser interferometry may not be able to look at what we need to look at to determine what EnABL does. I'm guessing that a microFlown might be the more appropriate tool -- and to get the most out of it you'd need an anechoic facility, so a milliom bucks would be a budget facility.
dave
Nifty, but it should show up in the holograms just as well and show you the patterns.
I concluded my crude attempts at doping the 125's. Quite successful for a safe only one pair experiment. The "conclusion" from my experiments is that if one wanted one all done up, they should just see you. Quite educational. I would not have given as much weight to the mods had I not dabbled in it a bit myself. The real payoff is in better ability to read OEM data sheets and to know how to buy a driver that does not need to be fixed up. That is the path I intend to stay on. Love that reed paper Seas.....
Old 8th August 2012, 08:05 PM   #22
Bigun is offline Bigun  Canada
Bigun's Avatar
http://www.diyaudio.com/forums/multi...listening.html
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 8th August 2012, 08:15 PM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Laser interferometry lets you look at the cone. MicroFlown looks at the air being driven by the cone, they do no show the same things.
I saw you post that you were going to take them over to Doug's to try in his cab. Yesterday i just finished up a colour matched set for our proto Fonken125T which will free up a set. I thot i might ask if he'd like to borrow the spare set (me knowing that it would give you a chance to evaluate them too) -- i've not had a chance to contact him about that yet (Hey Dougie!!!)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th August 2012, 11:04 PM   #24
ODougbo is offline ODougbo  United States
Well Sir, I would be honored. I'm sure my MD counterpart would be very excited to audition them also.
Doug
Old 8th August 2012, 11:21 PM   #25
frugal-phile(tm)
planet10's Avatar
OK, i'll get them together.... and send you an email with conditions (easy to meet)
dave
Old 8th August 2012, 11:37 PM   #26
I should have an upgraded pair of boxes done by the time they arrive; now that there is a mission, that would be a sure bet (-; (-;
Old 8th August 2012, 11:57 PM   #27
frugal-phile(tm)
planet10's Avatar
Given the differential between how quick you get things done, and i get things done -- particularily given that i'm also prepping for VI diyFEST, i'd bet on you
dave
Old 9th August 2012, 01:17 AM   #28
Default The Truth Is
I had a head start
Old 10th August 2012, 12:46 AM   #29
Default Second construction pic.
Cut length for backs and sides at same time - the box self alines square (because of the "triangle") for glue/clamping.
This is a dry fit; cork next, then glue/clamp up on corner of work bench.
Last edited by ODougbo; 10th August 2012 at 12:50 AM. Reason: (because of the "triangle")
Old 11th August 2012, 12:21 PM   #30
Default Still plugging along
Pic 3
Please recommend a desktop fullranger?Hide this!Advertise here!
Best fullranger for voice? phil09 Full Range 10 14th February 2012 09:09 PM
BiB for Aurasound Fullranger? mctavish Full Range 8 2nd February 2011 12:15 AM
Waveguide with piezo above fullranger Racket Scientist Full Range 6 8th December 2010 03:12 PM
New Ebay 4" Fullranger sharpi31 Full Range 34 7th July 2010 05:23 PM
What to build next (or, convince me to try another fullranger)? leadbelly Full Range 16 27th March 2007 10:34 PM
Copyright ©1999-2017 diyAudio
