FE166En+FT17H "Concerti clone" (lots of pics!!) - Page 10 - diyAudio
Old 4th August 2012, 12:48 PM   #91
And for now the last picture.
A lot of curves with a lot of listening in between.
Xander's choice : light blue and green for the second speaker.
Almost 40Hz "in-room" ; not bad at all.
Holographic / ESL - like sound with FAST bass.
Xander said to me that after optimising everything it sounded at least 100% better than before.
They now have a price/performance ratio of 12 (Xander's words ; not mine!!......but......they are SOOOOOO GOOD!!)
So for everybody building :
Give them break-in time.
Use a tweeter !! ( most resonances people think to hear are conus anomalies ; not design failures!!)
Experiment with romm placement and sit about 3/4 metres away from the speakers.
Good luck to everybody and enjoy!!
Leon
Old 4th August 2012, 12:50 PM   #92
Almost forgotten!!
To Dzius : Xander is going to try your series x-over ; will keep everybody updated as soon as I hear about it.
Leon
Old 4th August 2012, 02:44 PM   #93
Dzius is offline Dzius  Poland
Dzius's Avatar
After I'd listen for a while I've decided to use a little bit of baffle step compensation and reduce capacitor value to 1.68uF. So my crossover right now looks like this:
I haven't done any measurement so far but while playing test signals I can hear 35Hz.
Old 4th August 2012, 04:59 PM   #94
I am curious: what optimisation that Xander has done on the speakers? The three SPL vs. Freq graph differs a lot. I hope that I can have the speakers of the third graph.
Old 4th August 2012, 05:02 PM   #95
Thanks Leon for bring us such a good design. I believe the 12x p/p is not exagerating.
Old 5th August 2012, 02:57 AM   #96
In my previous post you see ...
A proper 45Hz , in room is also possible!!
The left and the right print differs significantly. Was this due to the environment, eg. room etc. ? And I am wondering why all the measured SPL below 90db? I remember there is another measurement done by Bob Brines, which was done in a big garage and did show that the SPL vs. Freq was quite consistent with the driver's published spec, except some elevated bass.
Old 13th October 2012, 08:22 AM   #97
Dzius's Avatar
After experimenting I put two layers of 6mm felt at the bottom to "smooth" sound a bit.
Looks like that's proper amount of damping. Still enjoying how it plays every day
Old 14th October 2012, 06:52 PM   #98
Question Final crossover?
Attachment 294531
Hey Dzius,
How is this crossover doing? I'm interested in trying to build this project too!
Has anyone flush mounted these drivers? I like the way that looks.
Old 15th October 2012, 06:04 AM   #99
Dzius's Avatar
Crossover is doing very well I recomend it. I tried many other setups but this one plus First Watt F3 is probably the best. Baffle step correction is a matter of room acoustic and personal taste of course. I'm planing to test direct connection FT17 to the amp output with 1.68uF cap and 3ohm resistor in series too (just for research) . Nonetheless these speakers are just fabulous judging it by ears. They play live music not just reproduce it. You can't figure it out of measurments or specs. I invited friends who are musicians the other day to confront my stuff with their instrument sound memory. After playing many differente pieces of music their final opinion was very good.
Old 16th October 2012, 09:17 PM   #100
Question Target specs?
Yes, I also think it's smarter.
Took me several drawings to reach my target.
By placing just ONE panel different I succeded getting a hybrid horn that was without parallel pieces.
The other differences are a result of HornResp and AJ-horn.
No, I don't have any measurements ; but I own , about 14 , different sets of loudspeakers to compare to.
This design is one of my best!!
I used the same cd's to voice them as for my "Eidoclone's" ; the midi concerti's hold up very wel!!
You can adjust the CC by adding some woodblocks inside by ear.
Do you have the line length and the pipe tuning? the target anyway?
also, your speaker pics show one that looks like one I've seen at humblehomemadehifi.com.
Finally completed "Delta" enclosure (pics) David Gatti Multi-Way 39 26th April 2012 12:27 PM
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
Music with lots of "emotion" Fast1one Music 57 18th April 2010 06:10 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Copyright 1999-2017 diyAudio
