Old 15th July 2011, 01:17 AM   #1
Bill poster's Avatar
Default 1.5 way crossover question
crossover dunce
If I were to use two identical FR units (per side) and put an inductor on one, that one would be 90 degrees out of phase from the other..is this right?
Cool Loudspeakers Facebook group
http://www.facebook.com/media/set/?s...24506880902633
Old 15th July 2011, 02:29 AM   #2
tuxedocivic's Avatar
Not for the whole range, rather changes across some point I believe.
Old 15th July 2011, 03:03 AM   #3
frugal-phile(tm)
planet10's Avatar
The 0.5 driver will roll thru 90 degrees as it crosses over. Below that it will be in phase
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th July 2011, 03:55 AM   #4
Thanks guys. so will that mean some kind of cancellation issue?
Old 15th July 2011, 04:00 AM   #5
frugal-phile(tm)
planet10's Avatar
Yes... somewhat.
dave
Old 15th July 2011, 10:48 AM   #6
Thanks Dave, I'm not sure what this does to the response (2x chr 70s)- I guess that the 2nd driver x/o shd be set quite low (chr70 has an amount of built in baffle step compensation).
The other route was to have some kind of reflector on one driver (instead of x/o).
Old 15th July 2011, 03:20 PM   #7
I recently saw a suggestion to cover the woofer in felt. Like a thick grill. I thought that was pretty good thinking. They didn't say if they've done it and it worked. But I thought it likely would.
Old 15th July 2011, 05:44 PM   #8
Felt? not sure how that works
will experiment with both an x/o and the reflector to see what sounds better- started building the 'buck' for the mold; still a month away from finishing the build tho
Old 15th July 2011, 05:59 PM   #9
Squeak is offline Squeak  Denmark
Squeak's Avatar
Pointing the two drivers in different directions would work better I'd imagine.
Old 15th July 2011, 06:08 PM   #10
Yes, I like Jim Griffins bipole designs
I've stuck with the shape I came up with for the cabinet, with 2 drivers facing forward, so will stubbornly see it through
Crossover question anonomouse Multi-Way 7 3rd July 2011 07:25 PM
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
Crossover Question cantskienuf Multi-Way 4 13th October 2004 09:59 PM
2-way crossover question dikarner Multi-Way 3 16th April 2004 05:52 PM
Page generated in 0.10292 seconds (76.79% PHP - 23.21% MySQL) with 11 queries
