Madisound BK-20
Madisound BK-20
Old 22nd July 2013, 07:55 PM   #31
saptemari is offline saptemari  Romania
OK, thanks again. I managed to find a kind friend who made for me a .dwg file with the measurements. This is my very first horn project. So, you can imagine I have great expectations. My amp is a 2A3 SE DIY
Regards to all,
Old 12th December 2014, 03:22 AM   #32
cervelorider is offline cervelorider  United States
cervelorider's Avatar
Originally Posted by chrisb View Post
Marius - count me among the folks who've commented on variable results with "Fostex factory" designs - I've heard / built several over the years and some of the larger Nagaoka manifold / BLH for FE206, etc are quite fine indeed, if not simple and lightweight. I recall helping a buddy with a pair for FE206ESRs which required something like 6 sheets of 5x5 plywood, and lots of patience on his part with the assembly
I've built some Nagaoka Tetsuo designs and built two of the BK-16 kits for those that couldn't themselves. I loved the BK-16 design, despite being an ancient, washed up, non-computer designed horn. Actually, I preferred it over a couple of the computer designed BLH's I've built in terms of overall musicality.
I love to build & listen to different designs, but don't know anything about computer designing horns. Question for the pros, how does the software account for the varying output impedances & dampening factors of various amplifiers? Does this not change the design as the driver reacts differently and thus driver specifications change? Does this not shoot some holes in the precision of computer modeling?
Old 13th December 2014, 03:18 PM   #33
xrk971 is offline xrk971  United States
xrk971's Avatar
Madisound BK-20
The sims assume that the amp can provide the current needed at the fixed voltage setting. So a constant voltage is assumed which is pretty good for most modern solid state class AB, class A, or class D amps. However, for wildly varying impedances that are too high, a tube amplifier designed for high impedance output may be better. In my experience though, te akabak sims of a BLH are very good.
Old 14th December 2014, 10:48 AM   #34
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
It is not beyond the wit of man to account for amplifier output impedance & its effects on the behaviour of a drive unit in the design of an enclosure, be it a horn or anything else. The ideal is to design for a specific amplifier, room acoustic & position et al. If not, then you ensure there is sufficient flexibility in the innate alignment selected to work with a range of amplifiers, room types and positions. Job jibbed. You can't please everyone, but you can provide a very effective compromise.
As for 'non-computer designed', probably the best performing bass horn designs in a technical sense were done by RCA, WE etc. back in the 1920s - 1940s when there wasn't a whole lot of digital technology available. Software allows easier / quicker design and can reduce (though certainly not eradicate) a lot of the physical prototyping & testing requirements. That is where the real advantage lies: speed & cost. You can hit broad alignments quickly; refinements can then be made via fine-tuning in the prototype stage & to an extent via additional simulation work.
Re 'musicality' since that varies from person to person, YMMV as ever.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Madisound BK-20Hide this!Advertise here!
Madisound Fostex BK-16 cabinents whitelabrat Swap Meet 2 12th September 2015 09:25 PM
Madisound Bk-16 Kit review JeffG Multi-Way 23 14th November 2013 01:28 AM
Fostex BK-20 as bass for H420 wood horn? Doug Kim Multi-Way 2 2nd April 2013 03:18 AM
Tang Band 1808 in Madisound BK-20 cab? Racket Scientist Full Range 1 25th February 2012 07:45 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 08:30 PM
