Martello enclosure for FR88EX - Page 13 - diyAudio
Old 4th November 2011, 06:56 PM   #121
frugal-phile(tm)
planet10's Avatar
Originally Posted by Bigun View Post
Wow, I didn't know the price was up that much, makes my little speakers more valuable
I invested in them before they went up. I have 22 of them.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th November 2011, 01:19 AM   #122
Bigun is offline Bigun  Canada
Bigun's Avatar
Will they be getting the polka dot treatment ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th November 2011, 01:45 AM   #123
frugal-phile(tm)
planet10's Avatar
At some point likely. We were considering doing them up as a fill-in for the old FF85, but the price jump and the new FF85 killed that idea.
We are likey going to build an experimental array
dave
Old 21st April 2012, 11:24 AM   #124
Bigun's Avatar
Well it looks as if prices are reasonable on these drivers (e.g. Madisound $39.90). I may build another pair.
I thought I'd update this thread with some more data.
First image are the calculations I used for the horn-shaped slot port.
Second image shows the simulated impedance curves for a straight bass-reflex design. Note the two peaks, typical of a BR design the interaction of the driver and box, they are roughly the same height. The simulated resonance peaks are at 50Hz and 140Hz.
Third image shows the measured impedance curves. I used my DIY TGM3 amplifier (solid state) with a resistor in series with the ground wire and a DMM across it to measure the rms voltage and used this to calcite the current and along with the signal amplitude the impedance of the speaker. I used a sine wave generator signal source. The vertical axis is not calibrated in Ohms but it is linear. The measured resonance peaks are at 50Hz and 140Hz, matching the BR simulation. BUT note that the left hand peak is much smaller - a result of the damping provided by the Onken style ports.
Old 19th May 2012, 07:56 PM   #125
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
I realised now that tomorrow will be a boring day with nothing to do. Why not use some of the scraps of 12mm and 22mm particle board in my garage and build a pair of Martellos? This time I will focus on making them look as good as possible and if they turn out well I'll buy drivers, binding posts and damping material
Should be able to build a pair in just a few hours
My audio and DIY blog: http://phimusic.blogspot.se/
Old 19th May 2012, 11:38 PM   #126
jimbro is offline jimbro  United States
Must be nice not to have an infinite list of honeydos. Make hay while the sun shines. You're time is coming:-)
Old 20th May 2012, 01:45 PM   #127
Rullknufs's Avatar
Most pieces cut
Took more time than expected because my dad had "stolen" all the tools so all I had was a handsaw... And when I came to the point of putting the pieces together I found out that I had no glue and no wooden plugs :S
Old 20th May 2012, 07:51 PM   #128
Bigun's Avatar
over here it's a long weekend, we get Monday off - the country celebrates Queen Victoria's birthday and we do that with horizon-to-horizon blue skies, 30 deg.C and a cold beer or two
Good luck with the build - but it's handy having the drivers to hand in order to size the opening / clearance whilst still keeping enough wood for the mounting screws to bite into - it's a bit of a balancing act so be careful with that.
and that's the other balancing act !
Old 20th May 2012, 07:55 PM   #129
Scottmoose's Avatar
So should we, back in the old country. However, we do have Her Majesty's Diamond Jubilee celebrations in a couple of weeks.
Old 20th May 2012, 08:02 PM   #130
Rullknufs's Avatar
We also had long weekend, but last thursday and friday was "free" for me. Unfortunately I had to help dad clear some huge (yes, huge!) fallen trees at our summer house. About +10c and rain those two days...
I'll be careful when doing the baffles, to make sure I got enough wood for the screws. Wont be easy but with some precision work it should work
Was +5c and rain today... Will be warmer tomorrow it seems.
MARTELLO-2, a mini-tower from a single 2' x 4' Bigun Full Range 60 3rd September 2016 06:35 PM
The Fountek Five for FR88ex planet10 Full Range 52 12th October 2014 09:32 PM
Martello Fr88ex awqawq Full Range 6 26th August 2012 11:24 PM
Need an amp for Fr88ex awqawq Chip Amps 0 27th July 2012 11:04 PM
FR88EX Fountek Vendor's Bazaar 10 3rd April 2012 10:21 PM
Copyright 1999-2017 diyAudio
