Hello everybody, i am a newbie from taiwan. Just join this big family few month ago.
I was buy a pair of Tangband W4-1320SB Speaker from online store.But i don't have a good enclosure design can install two speakers. Then i searched internet and found TABAQ enclosure which design by Bjohannesen. It's a very good design, but it's too big for my room. So i search this forum again and found some rules to change origional TABAQ design. I follow these rule and MOD TABAQ to bookshelf size like Fig1, and entire structure like Fig2. ![]() Fig1 TABAQ bookshelf enclosure design draw by Google 3D Sketchup. ![]() Fig2 TABAQ bookshelf enclosure entire structure. Is this design good to use? If not, how to MOD it? Did i miss anything else? Sorry for my poor english. Thank you read this thread and reply. |
#2 |
Greetings!
I don't know if this would work or not, but I really like your take on the TABAQ. I'm currently building a couple of pairs as gifts for friends. I'm intrigued by the size you've come up with here. Would this be as versatile as the tower TABAQ- as far as rolling drivers? Could this use the W3 speakers as well as the W4? Would it use the same BSC as the tower TABAQ? If so, I think I may have just found my brother's birthday gift. It doesn't look like a lot of lumber. If your ambitious enough to follow this through, PLEASE keep us updated. Inquiring minds want to know! PS: Your english is just fine. |
#3 | |
I found some mistake on the design, the port cross section is not as same as origional cross section. I will fix this mistake and update figure later. |
#4 | |
Update two figure here. ![]() Fig.1 TABAQ bookshelf enclosure design with fix port size draw by Google 3D Sketchup. ![]() Fig.2 TABAQ bookshelf enclosure with fix port size entire structure. |
#5 |
I was build a prototype for this cabinet design, which is making by 18mm lauan plywood. Compare with last design, i was fix internal compartment configuration and put the BSC circuit in this space.
The sound is great. Plywood bring bass brighter, more dynamic and deeper than original design, but port size is very hard to cut. So i will modified the port again in my final design. ![]() Fig1. Prototype cabinet. ![]() Fig2. Internal compartment configuration. ![]() Fig3. BSC Circuit. ![]() Fig4. 2D Sketch. ![]() Fig5. Mass Loaded Port. ![]() Fig6. Compare with original TABAQ cabinet. |
#6 |
Looks like you've been busy! What driver did you use for your prototype? Does this version use the same BSC?
#7 | |
Thank you posting your design. Looks good and I am thinking building the bookshelf version (no space for the tall version) One change I would have made is make the filter accessible - if continuously playing at loud levels the resistor may not be able to dissipate the heat. Let us know how it sounds (Do you have also the floorstanding TABAQ? How does it compare?) AM |
#8 | ||
I use TangBand W4-1320 driver and same BSC with it. Quote:
My prototype is making by 18mm lauan plywood. Compare it with original TABAQ enclosure build by 18mm MDF, prototype bring bass brighter, more dynamic and deeper than original design. I just upload two designs to google 3D warehouse. One design sketch with vertical port and the other one with horizontal port. These designs has same port cross section and same port length. Links: 1.Vertical port 2.Horizontal port Thank you read this thread and reply. Best regards. |
#9 | |
Thank you for reporting the results, I was expecting exactly that. The BBC had a study on the materials used for cabinets anf found that thicker is more difficult to dampen - this is in contrast to popular belief. (BBC RD1977/3 Factors in the design of loudspeaker cabinets) I'll be making it of 12mm ply, this is the same thickness as the BBC LS3/5A. edit: I do like the horizontal port for visual effect but the vertical port is better for horizontal dispersion and will be less affected by sitting on a table / shelf. Vertical port it will be :-) . AM Last edited by AmadeusMozart; 14th May 2010 at 01:24 AM. Reason: forgetting to mention one item |
#10 |
PS
G L Auspurger mentioned that to supress resonances in a transmission line the speaker can be best placed 20% from the end (of the transmission line). ( http://diyaudioprojects.com/Technica...mped-Pipes.pdf ) Kind regards, AM |
| Suggestions: Stereo Mid-Bass/Sub enclosure 'stands' for Bookshelf speakers | Kilroy | Multi-Way | 6 | 11th March 2010 05:05 AM |
| Small bookshelf design needed | x | Multi-Way | 9 | 8th May 2007 03:28 AM |
| Building a full range bookshelf enclosure | aussiebuddha | Full Range | 6 | 10th August 2006 04:31 AM |
| Cheap, small bookshelf design... | Nm2285 | Multi-Way | 3 | 19th July 2005 10:32 AM |
| 2-way large bookshelf design | Nm2285 | Multi-Way | 5 | 21st September 2004 03:38 AM |
| Page generated in 0.15103 seconds (83.52% PHP - 16.48% MySQL) with 11 queries |
