microTower bipolar ML-TL for CHR-70 or EL70
Old 24th December 2011, 05:23 PM   #451
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Merry Christmas Guys
I trimmed the sides and added the vents/feet to the case. The vent jig worked a treat.
I've just hooked them up again but its pretty much the same, maybe slightly better. I cant think of anything else...well apart from an air leak. I'll have another go during the hols and report back.
Have a good time!
Old 24th December 2011, 09:31 PM   #452
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Hey! Isn't that one of mine in the background?
Bob
Old 24th December 2011, 11:37 PM   #453
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Tripmaster, et al...
Merry Christmas and a Happy New year to all. Else Happy Holidays if you prefer (Hannukah, Kwanzaa, or whatever else is your holiday this time of year).
Tripmaster: Besides the steps that you have already suggested or have agreed could be done, please paint the inside of your enclosure. One of the most convenient and quickest methods to help seal "leaky" (as in MDF, HDF , chip board and regular plywood) enclosures. If you used an open cell type foam for the gasket(s) replace them with something more like compressed EVA material. Not sure how readily available it is, but I am sure it must be available as a tape or similar someplace.
But tonight just forget about it all and enjoy the evening.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 25th December 2011, 03:00 AM   #454
GM is offline GM  United States
GM's Avatar
Bob
Are you putting 'doughnut' rings on them now?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th December 2011, 08:58 AM   #455
Tripmaster's Avatar
Bob
Might be
Old 25th December 2011, 09:01 AM   #456
Tripmaster's Avatar
GM
Those are to stop the pesky 3 and 5 yr old fingers!
Old 25th December 2011, 09:07 AM   #457
Tripmaster's Avatar
Will do. I will leave the painting as a last resort as its will get a bit messy ripping out the stuffing. The seal is made of rubber, rather than spongy foam. I will hunt out the packaging and check the material.
...anyway, I think another mince pie is in order!
Have a good day!
Old 26th December 2011, 06:06 PM   #458
Tripmaster's Avatar
Hi Nanook
I hope you had a good Christmas.
I have a tub of PVA that is a few years old, and I prefer using other brands now. As I will need to reattached the lining to the cabinet sides, how about mixing up a thinned PVA solution, paint the inside and reattach the wadding...kills two birds with one stone I guess.
Old 26th December 2011, 10:35 PM   #459
Nanook's Avatar
Default thinned PVA...
Tripmaster:Thanks for the X-mas wishes. I can't imagine why it would not work if you are willing to pull out the stuffing. This is one of my pet peaves. MDF chipboard and even HDF "chuff". I don't wan to start another pro BB ply thread or hijack this one. Either do as you suggested or paint the interior of the enclosure using a spray can, either one will be an improvement and(I think) will be enough to improve your enclosures.
Happy New Year to all
Old 6th February 2012, 11:59 PM   #460
bobtrancho is offline bobtrancho  United States
Default Room placement question
I will be moving to a new apartment in a couple of months and am starting to think about the placement of my castle microTowers. Obviously, I'll have to wait until I get there are start to play with the exact placement but I am somewhat constrained as to where they can go.
Below is a floor plan that shows the approximate relationship of the speakers (red dots) to the sofa (brown rectangle). The small blue rectangle is a radiator. The dark red rectangle is my source/amp table. The room is 14' wide and has an 11' ceiling. I won't be able to spread the speakers out more than 8 -9' apart because the dining table, etc need to live in the other part of the room.
My question is - how far out from the wall can I bring the castles before I start losing/defeating the effect of the top speaker? Is 18" too much or is this so room dependent that I'll just have to wait until I get everything in place? I have a small sub woofer to fill the bottom end if needed so I am less worried about bass than detail, sound stage, and overall imaging.
microTower bipolar ML-TL for CHR-70 or EL70Hide this!Advertise here!
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 48 18th October 2012 04:24 AM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Bipolar electrolytics dsavitsk Parts 3 8th January 2006 10:48 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 07:48 AM
Copyright ©1999-2017 diyAudio
