Mark Audio CHR-70 Application Thread
Old 5th May 2010, 03:31 PM   #501
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
OK I'll have to appologize for my lack of input here but I've been busy with life.... Pics and review still to come folks I promise....
What was that?... I can't hear you I have a line array filling my ears.
Old 5th May 2010, 03:56 PM   #502
chrisb is offline chrisb
don't apologize for having a life with which to get busy - enjoy it while you can
kinda burnt out - taking a break
Old 6th May 2010, 09:23 PM   #503
Nanook is offline Nanook  Canada
Nanook's Avatar
Default please don't apologize...
er, I thought life was the big deal...audio is but a nice little diversion
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 6th May 2010, 10:14 PM   #504
Nanook's Avatar
I can say from first-hand experience that the resistive Onken-style cabinets are very good. I've spent perhaps a total of 2 years listening to a few of Dave's designs.(they are all very good), but the Onken styles are best (methinks). Here's a really simple experiment for any that feel that resistive vents are but a fantasy: If you have a pair of typical Bass Reflex enclosures with suitable drivers in them (commercial or DIY), get em out of storage or wherever you have them and put them into the best system you have access to. Play music that you love (and know well), preferably acoustical but electric blues/jazz, etc is good too (full orchestral pieces can be used too, if not too complex).
Listen at a reasonable level, just don't overdrive the speakers, for at least a couple of songs to re-accustom your ears to the sound. Now get ye a handful of drinking straws and bind a them together with an elastic band. Cut them to the length of the ports or slightly longer. Stuff them into the ports of the loudspeakers. Listen again, without changing anything else (including the volume control). If subjectively the level seems lower, then overall the distortions have been reduced. This suggests a reduction in bass distortion, and more accurate bass. It'll cost ya about 50˘for the whole "experiment. You be the judge.
This is what the Onken style cabinets can do (and aperiodic designs as well). It would be instructive to overlay a frequency sweep below, say, 1K, in a BR, a "stuffed vent BR, and an Onken enclosure, everything else being equal (within reason), and an aperiodic. (I have no testing equipment except what is between my ears). just a couple of thoughts.
Last edited by Nanook; 6th May 2010 at 10:16 PM. Reason: removal of asterixed text.
Old 7th May 2010, 08:46 PM   #505
AmadeusMozart is offline AmadeusMozart  New Zealand
Originally Posted by Nanook View Post
..... Now get ye a handful of drinking straws and bind a them together with an elastic band. Cut them to the length of the ports or slightly longer. Stuff them into the ports of the loudspeakers. Listen again, without changing anything else......
I wonder what this effect this would have in the Metronome?
Another item I wonder about with the Metronome is what effect padding the base plate (holding the port) with damping material would have....
I am also wondering what the effect would be that instead of having a pipe (round port) of a determined length to have a pipe that has a Karlson slot from 1/4 of the end to the end. The length will need to be increased to where the "center" of the exponential opening area is at the same location as a normal port would finish.
Just musing about possibilities to improve the Metronome.
(build Karlsons in the past and found them very forgiving about different resonance frequencies in the different speakers)
AM
Old 7th May 2010, 09:56 PM   #506
BudP is offline BudP  United States
BudP's Avatar
I have always used four small ports, sized to be effective with just the wood thickness as their length. You can use Bass Box Pro to model this, and I assume other programs also. By ear/sight, place a small bit of fluff in one of the four holes and tap the woofer, if it flies out you are just about perfect. I do have a set of stepped drills (both letters and numbers) for this purpose, among many others.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 22nd May 2010, 04:14 PM   #507
TheSeekerr is offline TheSeekerr  Australia
Drumroll please.....
The dMar-Ken70's are finally making music.
In brief: they're pretty nice.
Defining characteristics: Heaps more bass than you'd expect, and a nice extended top end. In this cabinet, the CHR-70 is very nearly a "full range" driver.
Oh, and for all that they're low efficiency, they play plenty loud enough - I've been testing with a 15W Class-T amp. I think we sometimes forget that 90dB is actually pretty loud.
Old 22nd May 2010, 06:43 PM   #508
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
When you get a chance, send me some big pictures to post.
Is that a MacBook posing with the coffee cup?
Our dMar-Ken7 are playing (A7s are still stock, Chris has them ATM), the dMar-Ken70 await veneer and a set of the CHR Mk2.
If i feel these work out (an so far all the reports indicate they will), i'm thinking of a variation made of Blanda Bowls.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd May 2010, 02:17 AM   #509
For shame, Dave, it's a TEA cup.
The Mac (as well as the speakers, once they're finished) belong to my girlfriend - I can pose my sister's MacBook for the bigger shots if you think my Dell might spoil it :P
(incidentally, Apple's habit of turning off the integrated sound card to save power is really repulsive - you hit pause and all is silent, then it starts to hum. Then you hit play and it produces an almighty POP! when it switches back on. Not exactly ideal, that.)
I'll charge up the real camera to grab some better shots later - they're still pretty rough, nailgun pockmarks everywhere - and 3 of the 4 chamfers show a brad sliced in half by the circular saw. But that'll mostly clean up once they're filled, sanded and painted.
EDIT: Oh, and do let us know how the dMar-Ken7's compare to the 70's once you have them both playing.
I'm still really impressed by these - the same comments I made back when I was playing them bare still apply. Voices are stunning, imaging is quite remarkable. The only difference is an improvement - they have ample bass, and seeing these little cones swing 4mm whilst playing (quite sucessfully) the infamous TR-808 kick drum sample is hilarious.
Oh, and they can do rock surprisingly well - they never sound strained at lounge room volumes. They're never going to give "the concert experience", but I could live quite happily with these as my only speakers - unfortunately, they're going away, to join the shiny new computer I built, and the DAC that I built, and the amp that I haven't built yet. Why can't I afford to build all these nice things for myself?
Old 23rd May 2010, 03:20 AM   #510
frugal-phile(tm)
planet10's Avatar
The Dell would spoil it.
I've never run into that. But then i've not been able to afford an Intel Mac yet, and i almost always use an external DAC (firewire, but i have a USB backup)
You can be sure i will.
Adding a pair of helper woofers goes a lomg ways
Make sure you make a profit on each one...
dave
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
