Mark Audio CHR-70 Application Thread
Old 26th April 2010, 09:51 PM   #491
jimbo1968 is offline jimbo1968  United Kingdom
Thanks Chrisb, you certainly picked up on what I was thinking!
So the only way I can put my sceptism to bed, is to build one to planet10 spec, or wait and visit someone local who builds one.
But what if it sounds like the box I just built? Does that mean I got lucky and stumbled on a great design, or does it just mean I don't have very discerning hearing!
I dread to ask, but is the 'majik' measurable? Where are the plots of majik and non majik boxes?
Old 26th April 2010, 10:16 PM   #492
chrisb is offline chrisb
I guess the answer to 1) is yes, and 2) is - it would have to be the former as no frequent DIY pos(t)er would admit to the latter
geeze, I just confused myself
only by the smile on one's face
actually, I'm a bit surprised that I haven't heard from Ivor's lawyers about trademark infringement .... oh wait a sec, there's the doorbell
(that's a joke, 'cause they'd never ring the bell )
I just always liked the spelling of that word
I don't know if Dave has actually measured anything recently other than drivers raw T/S during the EnABL treatment and matching process
kinda burnt out - taking a break
Old 26th April 2010, 11:36 PM   #493
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We are waiting till nice whether, a gangplank will be built and we'll be able to get proper free-field results down to ~50 Hz. Measuring kit this summer will be much better than last summer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th April 2010, 11:49 PM   #494
frugal-phile(tm)
planet10's Avatar
The Majik happens 40-50 dB down from the main signal.
Probably measurable using available tech, but not usually with the tools mear mortals can afford (lase vibrometry, laser interferometry, microFlown). And then comes the whole correlating measures to what is heard.
dave
Old 27th April 2010, 12:00 AM   #495
BudP is offline BudP  United States
BudP's Avatar
The only measurement to date, that I think shows this 40 to 50 db down difference, can be viewed here.
Enable Tests
Note the difference in detail structure of the main resonant node's "nose". Note that the detail structure of the resonance is clearly depicted in one and pretty diffuse in the other.
We appear to be able to disperse these nodes too, but no objective data, other than from a Jordan JX 92, is yet available and it is buried in the original monster thread. No resonant node dispersion attempt was made on the 7 inch aluminum drivers that John K treated with a generic pattern set and tested, showing that improvement in downward dynamics Dave is claiming.
I am sure you will be able to hear it, though some folks take a bit of time to understand what is showing up, as it is not something different, just less confusion and a coherence down to the end of all information.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 27th April 2010, 12:34 AM   #496
I was interested in the difference between dMar-Ken box and other 9l BR boxes, not the eNabling thing. I assumed the driver was a constant in speakrsrfun's comparison of boxes.
Old 27th April 2010, 05:40 PM   #497
Independent of the "EnABL thing", and my earlier post might not have been clear enough on this point, but we definitely found in several iterations of different volumes of enclosures for the FE127E and FF85K that the "prime" or "milli" style enclosures that descended from the original mini-onken design for the CSS FR125 had sonic advantages over more conventional (i.e. single or even double) rounded port enclosures of equal internal volume and tuning frequency. Specifically more cleanly articulated and smoother extension on lowest couple of octaves, and the narrow profile and chamfered edges improve imaging - wrap some polka dots around the baffle and side panels, and these can pull quite a disappearing act.
Perhaps there are some measurements reflecting the objective effect of the resistive slot ports?
Old 27th April 2010, 06:47 PM   #498
BudP's Avatar
I agree. These are the most invisible speakers I have had in my system (Fe127eN and Fonken prime boxes). The bass is clear and detailed into the mid 30's with power that scales to that of the higher frequencies, rather than starting to compress as the spl goes up.
Quite startling to hear pipe organ music, coming out very clearly during the intervals between voice coil exiting the gap, from the 16 Hz signals. Very clear and clean and momentarily silent and back to very clear and clean. Heard in a 30 X 60 X 12 foot room while playing one of the pieces from Cantate Domino and filling the room with everything except wall shaking bass, from a pair of 4 inch drivers, at a Pacific NW Audio Society demo.
I think I was most impressed with the robust character of the system and the control over the driver that the resistive ports provided, under those extreme conditions.
Bud
Old 27th April 2010, 09:54 PM   #499
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
OK let me clarify that my comparison is based on three different BR style boxes all running with first gen CHR-70 stock. My 9L ported/BR design is just a standard slot loaded design tuned to roughly 55Hz, 7L ported tuned to 70hz and the dMar-Ken. I never did any real posting of these designs because many have done it in the past and it seems redundant to post another CHR-70 BR design without it being a different beast altogether. With that being said the dMar-Ken for the CHR-70 seems to be much better braced and a much less resonant cabinet than the standard open box and brace design the BR generally allows. Not only is there an off center brace but the slot resistive ports are providing some pretty extreme rigidity themselves and the driver itself is coupled to the central brace. Another thing I have noticed so far is due to the ports being built the way they are in the deci style cabinet it acts somewhat like a constrained layer and eliminates most of the transfer of cabinet vibration that a standard BR box isn't privy to. I would say at this point that’s where the better definition and punch in the bottom end are coming from, more or less an inert cabinet and the resistive ports. I’ll elaborate later in my review…
What was that?... I can't hear you I have a line array filling my ears.
Old 27th April 2010, 10:21 PM   #500
as Dave would say
or
yup, that's what we've been saying
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
